A/C high pressure hose r&r
Old 24 Jul 2011, 11:34 am
PtBrewzer's Avatar
Default A/C high pressure hose r&r
Has anyone replaced the high pressure hose for their A/C? Mine is leaking, verified by the green dye coming out where the rubber part of the hose connects to the coupling. This is an area that I have never delved into, so any help would be greatly appreciated. Is this a job best left to a mechanic or can I do it in the driveway?
04 Platinum Series Turbomania.......
Old 24 Jul 2011, 12:52 pm
Default Re: A/C high pressure hose r&r
If the hose has to be replaced, and from what you said, it does, the freon (R134a) has to be captured by the dealer or someone specializing in A/C work. Letting it out into the atmosphere is illegal.
You also have to refill the system making sure the pressures are correct on both the low and high side, add lubricant and some more dye.
My opinion: if you've never done anything like that, and for sure you don't have the right equipment to capture the old freon, I'd let a professional do it. If you have a couple places besides the dealer in your area, call around, tell them exactly what it needs and get estimates.
power steering low pressure hose blowing off UpstateNYCruiser Turbo Wheels/Suspension/Handling 21 12 Oct 2015 01:59 am
Power steering high pressure hose leak. canbug Tech & Performance Forum 2 13 Mar 2011 08:16 pm
Replacing Power Steering Pressure Hose wapasha General PT Cruiser Discussions 0 20 May 2010 09:08 am
2006 cruiser power steering high pressure hose TOMisKING Tech & Performance Forum 0 01 May 2010 03:38 pm
Need High Pressure A/C Hose for 2002 laudemont Classifieds: Want To Buy 6 17 Aug 2009 08:20 pm
