Wrong coolant?
Old 25 Jul 2011, 10:45 am
Default Wrong coolant?
Went in for a flush and new thermostat and they did not use the red coolant. Dose it matter? Is the red synthetic?
Old 25 Jul 2011, 11:12 am
cruserdad1976's Avatar
Default Re: Wrong coolant?
it does matter id do a flush and refill with Zerox G-05 it wont do much in the short haul btu opver time it will effect your water pump and radiator
Old 25 Jul 2011, 11:37 am
and the heater core ....I believe that's what happened with my wife's N/A...previous owner put the wrong coolant
Old 25 Jul 2011, 11:49 am
rcktpwrd's Avatar
If the system is completely flushed and different coolant is used it probably isn't that bad. I would still drain and flush with water and put the correct stuff in, Zerex G-05 or MOPAR coolant.
The real problem is when different coolants are mixed, they don't play well together.
Joel
www.rcktpwrd.com
Old 25 Jul 2011, 10:38 pm
compdr59's Avatar
We pay a lot of money to keep our cars running well. When it comes to the fluids recommended by the manufacturer, you pay a few dollars now so you don't have to worry about spending much more later. I just purchased Mopar brand coolant for $20. The universal stuff is just not worth the risks.
Old 25 Jul 2011, 11:28 pm
true but the zerox G-05 is the same really there is only so many ways to make some things
Old 26 Jul 2011, 10:26 am
Dino's Avatar
It's also a Chrysler approved coolant, the only one.
Old 26 Jul 2011, 12:46 pm
But there's a few brands that are licensed to carry the ATF+4 brand that Chrysler recommends.
Licensed ATF+4 Brand Names
Old 26 Jul 2011, 03:23 pm
rcktpwrd's Avatar
this thread is about coolant, what does ATF+4 have do due with that?
Joel
www.rcktpwrd.com
Old 26 Jul 2011, 03:34 pm
As far as ATF 4. What do you use as power steering fluid? I used power steering fluid but I am hearing use atf 4.
What's wrong with this picture ACESSS General PT Cruiser Discussions 14 23 Jan 2016 09:23 am
What did I do wrong? sniggle Wheels, Tires, Suspension 5 28 Jun 2011 09:09 pm
