Door Locks not working
Old 25 Jul 2011, 11:49 am
Default Door Locks not working
I have a 2005 Pt Cruiser convertible. Door locks suddenly stopped working. the remote will unlock the trunk but not the door. It takes a hard turn with the key in the door to open (I also have to hold the key in that position to open door). Once inside, I cannot manually pull up the lock knob. When I try the power lock button, all I get is a click behind the dash.
Old 25 Jul 2011, 03:30 pm
Default Re: Door Locks not working
Not saying this is your problem, but you have a module in the dash the works the locks through your remote. it could be bad.
Old 03 Aug 2011, 09:47 pm
The "hard turn" with the key in the door would indicate that actuator has failed, and is probable seized.
Some times you can go in a loosen it up, and grease it and be good to go.
But honestly, it sounds like you'll be replacing that actuator.
If you know someone with a scan tool, they can actually tell you whats wrong with the lock, and maybe if there is more than one that is failing.
Hope that helps
Tags
door lock
Headlights and door locks stopped working? CruiserDan Tech & Performance Forum 27 15 Jul 2015 01:50 pm
Headlights and door locks not working!!!! mmnester Tech & Performance Forum 6 17 Jun 2014 02:58 pm
Keyless entry unlocks driver door only- indoor locks not working Candace Tech & Performance Forum 9 14 Oct 2009 05:48 pm
Power locks not working! JHCT General PT Cruiser Discussions 1 30 Nov 2008 04:03 pm
Door locks not working blue04 General PT Cruiser Discussions 2 26 Jan 2008 10:38 pm
