HELP!!!! bad oil leak
Old 25 Jul 2011, 04:15 pm
Default HELP!!!! bad oil leak
We have a 2003 PT Cruiser, 5 speed. Clutch was replaced 6 months ago. All of a sudden we have a really bad oil leak (3 quarts in a week, and never had to add oil between oil changes at all before!)... not dripping on the ground at ALL...and the clutch is slipping like crazy! Someone suggests we have a bad rear main seal, however, reading your forums here, one of the mechanics posted he has never seen a pt in the shop for a rear main seal. Any ideas would be appreciated!!!
Old 26 Jul 2011, 05:26 am
Default Re: HELP!!!! bad oil leak
Since you have a new clutch, and now are losing oil and the clutch is slipping, it is likely the oil is finding its way onto the clutch. It DOES sound like a rear seal.
Old 26 Jul 2011, 10:10 am
cruserdad1976's Avatar
3 quarts in a week is ALOT it has to be going some place does the car smoke???
and id agree the cluch is close to the rear main just odd for it to go out all of a sudden
Old 26 Jul 2011, 11:50 am
I agree - that is a LOT. If it was only the rear mail seal you would *have* to be getting a mess of it on the ground. The bellhousing isn't that well sealed, and a) 3 quarts a week would literally fill the bellhousing in a few weeks or b) would be dripping (flowing!!!) onto the ground. Probably b).
How does the car run? As normal, or? I ask because a decent possibility is you have a cooked ring(s), and oil is being drawn into the combustion chamber and burned off, then air/exhaust is pressurizing the crankcase and forcing relatively small amounts of oil out one or both of the crank seals, possibly lubricating the clutch.
Put a piece of cardboard under the engine/transmission and let it sit for a day or two to be sure you're not seeing drips. If you're not, do a compression/leakdown test to be sure you're not dealing with an actual combustion chamber sealing issue.
Old 28 Jul 2011, 05:23 am
Okay, two drops the size of a nickle, maybe a quarter is all that's on the ground. I didn't think the bell housing would hold that much oil, but was told it was possible. With clutch slipping haven't driven it for a while, but it isn't smoking there is very small drops on the hatch, like rain, but seems like oil. Mechanic says he can't warranty the clutch if it's oil soaked, so I am looking at another 900 to 1200 for clutch and or seal...ugh.
Old 28 Jul 2011, 09:53 am
Dino's Avatar
Sorry, that really sucks!
Old 28 Jul 2011, 09:54 am
if you are saying it has FILLED up the bell housing dude that is just bad it would be hard for me to belive that is even doable
IF it does nto smoke its not going into the cylenders
if there is none on the ground its not leaking it while sitting
the last option is a presure leak while running
tyr this
cardboard on drive way start car and run it at a HIGH rev for 5 minutes it wont hurt anything and if it is a presuer leak it should show up
Old 28 Jul 2011, 12:06 pm
Where physically are the drops on the ground in relation to the car? How long was it sitting to generate this amount of oil?
If you have oil on the hatch, that is getting blown out the exhaust pipe or getting sprayed underneath the car and getting sucked up into the vacuum the hatch creates while you're moving forward.
Dad has solid advice - by 2000 rpm the pump should be making very close to maximum pressure, so leave it in neutral, hold it at 2k for a minute or two, and see what's on the ground. It'd be GREAT to have a helper with a flashlight looking around under the hood and under the car while you're doing this to more quickly spot what's coming out of where. I would be sure the car has a normal/full oil fill before starting, so you have the best possible test.
Tags
clutch slipping, oil leak
bad oil leak naford302 General PT Cruiser Discussions 19 12 Sep 2017 06:41 am
oil leak Wishbone Tech & Performance Forum 17 10 Jan 2011 12:48 pm
ATF leak? calicranberry General PT Cruiser Discussions 7 19 Jun 2005 12:00 pm
ATF Leak shlalk General PT Cruiser Discussions 12 24 Mar 2004 09:05 am
First Oil Leak? Ack! beebs General PT Cruiser Discussions 4 18 Oct 2003 10:55 am
