Ignition switch
Old 25 Jul 2011, 06:54 pm
Default Ignition switch
Hey everybody
Been having all sorts of wierd problems ,like one day horn works next day not.Start car up in morning and speedo doesnt work shut car off while rolling and restart everything is fine .Error codes come up restart everything normal.After a week my crew chief orders new ingnition switch and all went away.that i would pass this along,eveything runs thru that cheap switch.
Lt4 supr
A friend is building a big block tub'ed out pt here in fla
oh and by the way i just got clock last month at 234.75 mph over a 100 mile run in my boat..yaaa now it's time to sell it..I eat Miss Geigo..
dunn_family likes this.
Old 26 Jul 2011, 05:52 am
Default Re: Ignition switch
You have a lot of extra junk on key chain?
How much did it cost for a new switch?
Did you have to get new keys?
Old 26 Jul 2011, 10:00 am
About $80.00 no its the switch not the tumbler,never keep more than just a few keys on my ring.
Old 29 Jul 2011, 09:14 pm
txcruiser's Avatar
Hey all, I just bought and installed a new ignition switch,Borg Warner p/n CS861, $35.99 at O'Reilly's......let you know if it solves the problem with the instrument cluster gauges going haywire.
2006 PT Cruiser Base Edition, Bright Silver Metallic, NA 2.4 liter, 5spd but drive it like a turbo LOL
Old 30 Jul 2011, 06:36 pm
txcruiser's Avatar
I'm happy to report no more crazies from the instrument cluster - YAY!!
Old 12 Aug 2011, 09:11 am
I replaced mine too for the problems with the gauges going to zero, the warning lights coming on and sometimes stalling.
Been two months with no more issues. (btw, it was doing the above frequently and even minutes before getting the switch replaced.)
Old 12 Aug 2011, 08:35 pm
txcruiser's Avatar
Same results here, no malfunctions in the instrument cluster any more.....
The Gremlins are gone!! YAY
Old 15 Sep 2011, 09:40 pm
How did you remove the ignition switch? I tore everything apart, but it seems that there is no tab to remove the lock cylinder. Perhaps 2006 and up are different?
2006 PT Cruiser MTX Base
Magnesium Pearl
100,000km/60,000mi
Old 15 Sep 2011, 10:50 pm
Well, I got it done, but it wasn't pretty. Although my FSM says it covers 2001-2008, the 2006 model year is obviously different. I couldn't figure out how to remove the lock cylinder.
At any rate, I loosened the left bolt that attaches the tilt steering lever to the rest of the tilt assembly. This gave me enough room to remove the ignition switch and install the new one.
The only problem I ran into was breaking the little plastic pin that goes into the switch from the lock cylinder. I had enough room to work, but I became a little rough and it broke. The pin is for the warning ding when the key is left in the ignition or the lights are left on. It also disables the door locks from locking when the key is still in the ignition. I put the broken piece of the plastic pin into the switch itself and then re-installed. So far it seems to be working and doesn't appear to be much of a problem.
It it becomes a problem down the road, I'll have to figure out how to remove the assembly and replace.
Magnesium Pearl
100,000km/60,000mi
Old 05 Oct 2011, 05:58 pm
VNT's Avatar
VNT VNT is offline
So it sounds like a failed ignition switch on the 2006 PT for the funky dash going crazy problems.
Also Mopar Part # is 4685719AD, whopping 14$, much cheaper than the parts stores ,advance want 46$ for CS861 by BWD whoever they are
Oh this part is used in 2006-2008(maybe newer years too)PT and in 2006+ pacifica, avenger, sebring from chrysler parts direct site.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Ignition Switch Problem? jjensen101 General PT Cruiser Discussions 8 11 Apr 2013 07:15 pm
Ignition starter switch sconnors11 General PT Cruiser Discussions 5 19 Aug 2010 06:17 pm
Ignition Switch or transmission? scatgo Tech & Performance Forum 3 18 Oct 2009 04:15 pm
Ignition Switch??? Don162 Tech & Performance Forum 2 19 Aug 2009 11:03 am
Possible Ignition Switch? bkarr Tech & Performance Forum 4 20 Jul 2008 06:25 pm
