Check engine light and battery light on
Old 26 Jul 2011, 04:39 pm
Default Check engine light and battery light on
Hi everyone! Here is my problem, I bought my 2006 PT Cruiser (35,000 miles) 2 months ago. About a month ago my battery light came on, I took my car to auto zone to have them test it. I was told my battery and alternator were fine. A few days later the light went off and stayed off for about 2 weeks then it came back on. I took the car somewhere else to test it (just to get a second opinion) as was told the same thing and like before the battery light went off again after a few days. Yesterday on my way to work my check engine light came on and five minutes after that my battery light came back on. I checked for the "faulty codes" and all it says is "done". I checked the gascap and oil cap are both are tight. Does anyone know if this is a major problem? The car drives just fine. I love my car and I will keep my fingers crossed it is nothing major.
Thanks in advance.
Old 26 Jul 2011, 05:45 pm
My02RedRide's Avatar
Default Re: Check engine light and battery light on
What did they use to test the alternator? Alternator should put out 14.3 volts pretty constant with the engine running at idle. Engine off the battery should read 12.5 volts.
Old 27 Jul 2011, 05:44 am
Make sure the battery cables are on tight - you should not be able to wiggle them at the battery posts.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Check Engine Light is on-again lshykns Tech & Performance Forum 6 10 May 2011 08:21 am
check engine light azphotog Tech & Performance Forum 3 13 Feb 2010 11:45 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
