my engine is falling :(
Old 26 Jul 2011, 11:56 pm
Default my engine is falling :(
hi. i just made an account. i've had my p.t. for about 2 years now and i love it . i took it to get an oil change and they saw my tires were worn out. i bought new tires and then they told me that my engine was falling.
i'm missing an engine mount bolt. does anyone know where i can find one? i've looked at auto zone. oreily's, advanced auto parts and nothing.
ebay doesn't have one for p.t. cruisers any help will be greatly appriciated.
Old 27 Jul 2011, 05:25 am
Default Re: my engine is falling :(
Welcome toi the forums.
What did they say was failing with your engine??
GET ANOTHER OPINION.
Try RockAuto.com - good prices, awesome service.
Old 27 Jul 2011, 11:28 am
Dino's Avatar
Don I think he means falling not failing. I thought the same thing. Like Don said you get the motor mounts at rockauto.com or any dealer.
Old 27 Jul 2011, 12:27 pm
cruserdad1976's Avatar
you will ahve to get a complete Motor mount but rock auto or even orilerys will ahve a motoe mount for the PT
Old 27 Jul 2011, 01:26 pm
RaineMan's Avatar
Bad motor mounts (torque struts) are a common problem. The rubber parts die over time. I think most everyone here has replaced at least one.
Old 27 Jul 2011, 07:28 pm
UptownSport's Avatar
Sounds like he just needs a bolt?
Which one?
Old 27 Jul 2011, 08:18 pm
mdfrodolives's Avatar
If it's just a bolt that's missing, find out which one. But I suspect you have a sheared bolt. That's another issue. That means a lot more work to get the remaining part of the bolt out. Also, you have one center motor mount on the passenger-side of the engine--and one upper strut and a one lower strut (some people call these struts, motor mounts).
Check to see what mounting bolt is missing (broken). If a junk yard doesn't have the bolt you need, then you're going to have to go to the dealer. If it's the center motor mount, then you're in for some lengthy fixin'.
Tim
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
2003 Pt falling apart captmeach7 General PT Cruiser Discussions 19 16 Apr 2010 09:32 pm
... My pt is falling apart :( meganeliz Tech & Performance Forum 18 18 Dec 2009 05:34 pm
Can 2001 Engine be replaced with Newer Engine harleysforfun General PT Cruiser Discussions 1 07 Aug 2009 01:38 pm
BOOST STILL FALLING OFF ,PART 2 old head from phila. Turbo Performance 4 02 Jun 2003 07:38 am
