Catalytic Converter heat Shield
Old 28 Jul 2011, 08:19 pm
Default Catalytic Converter heat Shield
Where is this Converter heat shield located!!! I am working on new shift cable and after I remove the shift cable from lever pin it says to raise vehicle and remove he catalytic converter heat shield.
2005 Pt Cruiser Convertible Touring Edition
Jvc KD-R300 Dash Unit
Kicker K35 3.5in Dash Speakers
Pioneer TS-A1673R 6.5in Door
Pioneer TS-A6963R 6x9 Rears
Infinity Kappa 12in Sub
Infinity REF5350A 5 Channel Amp
Old 29 Jul 2011, 01:18 pm
Default Re: Catalytic Converter heat Shield
it's above the catalytic converter, bolted to the "roof" of the tunnel under the car.
Old 29 Jul 2011, 04:18 pm
it runs above the exhaust system in the tunnel area as stated above
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 30 Jul 2011, 05:57 pm
Sojack the front of the car up ?
Old 30 Jul 2011, 07:42 pm
I need to be honest: If you don't know where the catalytic converter is, much less the exhaust system, you may want to stop now.
Old 30 Jul 2011, 07:52 pm
^ X2
Old 30 Jul 2011, 08:15 pm
Well, job got done located all parts and even had time to do the tie rods. Finally ready for summer.
Old 30 Jul 2011, 08:57 pm
So you didn't know where the cat is let alone the heatshield for it. You didn't know if you had to jack up the car to do the cable job. But between 6:00 and 9:00 today you miraculously did it AND your tie rods at the same time! I think we are all feeling a major tugging on our legs (or we should be).
Jerry
Old 30 Jul 2011, 09:01 pm
Nope started @ 3pm pics comin up.
Old 30 Jul 2011, 09:16 pm
Center console, old tie rod ends
Upper heat shield hidinginparadise General Turbo Discussions 2 16 May 2011 03:37 pm
Catalytic converter & turbo scotchwriter General Turbo Discussions 6 27 Nov 2010 04:35 pm
Catalytic Converter Question VellianPT Tech & Performance Forum 15 18 Oct 2006 12:59 pm
Catalytic Converter CHROMEDCRUISER Tech & Performance Forum 2 13 Feb 2005 08:00 am
Cool-Air Tube Heat Shield tom-t-rifik Turbo Performance 6 28 May 2004 10:15 pm
