pt not charging.
Old 30 Jul 2011, 01:27 pm
eli eli is offline
Default pt not charging.
does any body have a wire diagram for a 06 pt turbo .i am still trying to fix my battery light . it stll does not charge my battery.Had the pcm fix new alt, new battery, and still the light is on and not charging.chase the wires and the mechanic says that one wire is ground and the other is the field wire . yes but on my car the black wire has 12 v and the field wire don't. the field wire comes from the pcm and the other wire goes in a wire harnes to the inside of the cab.or some were .thats way i was lookin to find a wire diagram.. any help will be appreciated ..
Old 30 Jul 2011, 02:03 pm
Default Re: pt not charging.
Don't know if this will help. It's not the turbo and it's from an older model than yours but it might lead you in the right direction.
Charging system issues Murdered Tech & Performance Forum 1 12 Feb 2011 07:37 pm
Charging problem lowridr General PT Cruiser Discussions 4 03 Nov 2010 09:18 am
Charging the Air Conditioner chuck2112 Tech & Performance Forum 11 23 Feb 2010 09:44 pm
UK crd charging question spiceweasel Tech & Performance Forum 6 15 Dec 2007 04:37 pm
Super charging Mr.Blonde Turbo Performance 7 29 Apr 2003 10:31 am
