P0882 Low input signal
Like Tree4Likes
Old 30 Jul 2011, 03:15 pm
Default P0882 Low input signal
For those who have had this code come up and the car goes into limp mode, the cause is a corroded wire that connects the PCM to the transmission harness, its attached to the battery tray mount by two plastic clips. Labor involves taking the connector apart and repairing or replacing the corroded connectors. Dealer charges 2 hours to repair.
Old 29 Jul 2013, 07:20 pm
eli eli is offline
Default Re: P0882 Low input signal
mine is 06 and the only wire that see in the battery tray is the ground wire it looks good
Old 29 Jul 2013, 07:27 pm
you have to take the battery tray out, the harness is under it. i havent done this myself, but i think ive seen the harness there when i did my own digging years ago when i had this issue.
Old 04 Jul 2014, 12:45 pm
My wifes 07 cruiser base 2.4 105k miles threw two codes yesterday p0700 and p0882. I have no idea were to begin this hunt. Normally I dont get frustrated and have always been able to fix my issues but this one makes me wonder if I should just take it to a mechanic. Do you have any advice on where to start. I have already pulled the battery and tray out. Looked at the wiring harness to see if any loose wires were visible on the top of the harness, saw none. Pulled out some sort of solenoid/sensor from transmission(seems to be two of them, only pulled one the easiest to reach) cleaned of some fine metal shavings. Not sure if I should replace them?. Read another post here stating it could/would be a corroded wire under battery tray. Any help would be appreciated as she needs the vehicle for work monday
Old 15 Jul 2014, 04:37 pm
Mine ended up being a bad TIPM.
2007 Base Pt 2.4L 105k
Old 26 Mar 2015, 06:49 pm
Thumbs up Re: P0882 Low input signal
my car (90K) had the same problem, in my case the P0882 code was caused due to the upper hose radiator, this hose was getting to hot and transferred the heat to the positive cable of the battery en the voltage down, so I just change the upper hose of radiator (cost me $6 on rockauto) and problem was solved!!
Old 26 Mar 2015, 08:17 pm
Wasn't there other problems with the voltage dropping when the upper radiator hose got hot?
Old 27 Mar 2015, 10:24 pm
PTpreacher's Avatar
Smile Re: P0882 Low input signal
Ghost, I am the person that posted those codes, I am going to check the connector under the batt. box. And if that doesn't fix it, I guess I will have to get a reconditioned TIPM.
I will post what I find out! Good Luck to you. PTpeacher
Old 22 Mar 2016, 09:26 pm
I'm having this code come up after my 2006PT Cruiser has gone into limp mode. What did you find out about the connector under the battery box?
Old 23 Mar 2016, 12:30 am
P0882-TCM Power input low
P0882 is set when there is less than 3.0 volts present at the transmission control output circuits located in the PCM when the Transmission Control System request the power up of those circuits.
Possible Causes:
Transmission Control Circuit short to ground (T15)
Transmission Control Circuit open (T15)
PCM
Auxilliary input help Fenrir Sound and Security Forum 19 06 Sep 2017 08:11 am
Aux input on radio ParrotHead PT Cruiser Convertible Forum 6 02 Sep 2011 08:42 pm
NEED INPUT!! ucantcme General PT Cruiser Discussions 10 01 Nov 2008 01:31 pm
Can I make an AUX input for 02 pt? hermtm2 Sound and Security Forum 7 04 Aug 2008 09:16 am
Looking to buy '04 Touring any input? nozzano22 General PT Cruiser Discussions 13 28 Jun 2004 04:16 pm
