Check Engine
Old 30 Jul 2011, 10:08 pm
Default Check Engine
Hello folks! Our Pt 2003 has its check engine light on so I took it to a local auto parts store and connected their machine, the guy said it the Oxygen sensor but it doesn't say which one, I'm planning on just changing both but my question is, is it hard to do? I'm not really well verse with cars but if its just a plug and play kinda thing i can do that ( I think?) is there any Schematics I can download??thanks in advance and keep on Cruzin'!!
Old 30 Jul 2011, 11:27 pm
Dino's Avatar
Default Re: Check Engine
Oxygen sensor
Old 31 Jul 2011, 03:09 pm
here is the error code p0456,p0442 and p0522..
Old 31 Jul 2011, 05:40 pm
P0456 Evaporative Emissions System - Small May be your gas cap, not on tight (3 clicks) or worn out and you need a new one.
From PT Do-It-Yourself.net;
P0442-Evap System Medium Leak
A 0.040 leak has been detected in the evaporative system
When Monitored: Engine Running. Cold start test. Fuel Level greater than 12%. Ambient temperature between 4C and 32C (39F and 89F) Close Loop fuel system. Test runs when small leak test is maturing.
Set Condition: The PCM activates the EVAP Purge Solenoid to pull the EVAP system into a vacuum to close the NVLD switch. Once the NVLD switch is closed, the PCM turns the EVAP Purge solenoid off to seal the EVAP system. If the NVLD switch reopens before the calibrated amount of time for a Medium leak an error is detected. Two Trip Fault.
Possible causes include:
1.Intermittent Condition
2. Visual and Physical Inspection
3. Evaporative Emission Leak Detection
4. Evap Purge Solenoid Operation
5. NVLD Switch Operation
Specialized equipment is necessary to run the majority of tests, however you can conduct a Visual and Physical Inspection of the entire Evaporative Emission system.
Check for the follow conditions:
1. Holes or cracks.
2. Loose seal points.
3. Evidence of damaged components.
4. Incorrect routing of hoses and tubes.
5. Fuel Cap gasket seal. (A loose gas cap can cause this DTC to set. Make sure gas cap is tight and in good condition. Ensure the gas cap meets OEM specifications.)
The P0522 DTC is: Oil Pressure Sensor Low - Oil pressure sensor input below acceptable voltage.
Lots of owners get a bad Oil Pressure Sensor located on the back side of the engine as you stand at the front of the car.
None of these have anything to do with the 02 sensors. They have their own particular fault code.
Old 01 Aug 2011, 04:57 pm
thanks crewzin so its not really my O2 sensor??i have to bring it in to a shop?? that sucks i thought i can avoid bringing it to a shop..
Old 03 Aug 2011, 02:55 am
Okay now the check engine lights is NOT on, not sure what that means or they just evetually turns off?? so now i need the oil pressure sensor replaced or something??I'm planning on having all the spark plugs and wires replace becs i have not done so and it has already 83,000 miles!
Old 03 Aug 2011, 05:37 am
The check engine light goes off if the problem is no longer present.
You can wait for it to reappear before you do anything.
Old 03 Aug 2011, 12:17 pm
well thats good news for me, but i still think it needs some kinda tune up though its been really sluggish..
Old 03 Aug 2011, 01:00 pm
When were wires and plugs last done?
Get a good brand of wires (stock ones are crap) - the stock champion plugs are fine - gap at 0.040.
If you haven't ever changed the air filter, that's a good idea, too.
Old 04 Aug 2011, 02:25 am
i have never changed any since i bought it new 2003
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine light firehawk536 Tech & Performance Forum 2 16 Mar 2011 09:42 am
check engine lite on thewhizard Northeast PT Forum 2 05 Jan 2011 04:25 pm
Check Engine Light On vicky52 Tech & Performance Forum 11 23 May 2009 01:23 am
CHECK ENGINE BORICUA General PT Cruiser Discussions 9 10 Aug 2004 07:58 am
