Front bearings on a 2003 P.T. Cruiser
Old 02 Aug 2011, 04:16 am
Default Front bearings on a 2003 P.T. Cruiser
Hello,
I have a Chilton 2001-03 Repair Manual and they do not show anything on front bearings. What I need to know is when do you replace them? And do you know of a repair book that shows how to work on them too.
Thank you,
Leroy
Old 02 Aug 2011, 06:37 am
Default Re: Front bearings on a 2003 P.T. Cruiser
Driving slow, make a turn to the left, then right, do you hear any kind of grinding noise? Another way is to jack each front wheel up (one at a time) and grab the wheel top and bottom and try to shake it, then grab on both side and do the same. There shouldn't be any play in the wheel.
Here's how to change the bearing.
Wheel Bearing Replacement
Old 02 Aug 2011, 01:34 pm
Thank you, I will try that out.
Leroy
Old 05 Aug 2011, 06:03 pm
Dill's Avatar
Mine will need replaced on my next inspection!
Front wheel bearings 2003 Pt cruiser turbo tjc General PT Cruiser Discussions 2 31 Jul 2011 05:32 pm
Front hub and bearings wanted PtBrewzer Classifieds: Want To Buy 4 14 Jun 2011 05:01 pm
Roaring sound from front wheels, Bad bearings? LoboMX Wheels, Tires, Suspension 6 17 May 2011 06:50 pm
Best front hub/wheel bearings to buy? Samson Wheels, Tires, Suspension 9 13 Aug 2010 11:45 am
How many front wheel bearings? scrisp2 Wheels, Tires, Suspension 0 22 Mar 2010 11:24 am
