o4 Cruiser wont start
Old 02 Aug 2011, 10:53 am
Default 04 Cruiser wont start
First off let me say HI to everyone here , I am a new user .
I have an 04 Cruiser non turbo
44 thousand miles on it
Engine light came on , so I did the key trick to get the codes and also used a handheld and the computer spit out the oxy sensor codes so I changed both and the catalytic.
Everything worked fine but every once in a while the engine light would come back on and stay on for a few days then go away . A friend of mine says that I need to drive awhile for the computer collect data and make sure everything was working fine .
I was sitting in my car waiting for parking when the engine light came on again and about 5 mins later the car just shut off . I tried turning it on but it would just crank and crank but wouldnt turn over .
I put handheld to see if I can get any codes but now no codes come up . I try the key trick and no codes come up.
Car Cranks strong everything works fine ,, just wont crank over ....... Any suggestions
And Thanks in advanced
Old 02 Aug 2011, 01:07 pm
Default Re: o4 Cruiser wont start
Chan, welcome to the forum. Without any codes except the one you took care of, it's hard to diagnose what's wrong. Usually when it acts like yours and just shuts down and cranks but won't start it turns out to be the timing belt but with only 44K it's hard to believe it would be that.
So, you gotta start with the basics and that fuel and spark.
Old 02 Aug 2011, 08:33 pm
Hi Crewzin,
After about 8 hrs or so I got some tools together and was about to start checking for spark and or fuel and decided to try and start her up , and boom she started right up .
Then after five secs or so she konked out . At this point Im guessing Fuel Pump. I checked relays and checked for sparks and all seems fine , So before I get down and drop the tank and remove/replace the pump assembly is there anything else I should check on
Old 02 Aug 2011, 08:45 pm
Instead of dropping the tank, borrow a fuel gauge and somewhere on the fuel rail by the injectors, there's should be a valve that you can hook up to to see if you have pressure.
testing fuel pressure,wheres the schrader valve?
Old 04 Aug 2011, 12:09 pm
Update:
I couldnt find gas valve on the rail (shrader) so couldnt do pressure test but weird thing is I can get my PT started but after 2 or 3 mins it cuts off
now I dont know which way to go
Old 04 Aug 2011, 12:27 pm
2 or 3 seconds and I'd say you have a SKIM problem but not 2 or 3 minutes. Think you might have to have it diagnosed with a good scanner to find out what's wrong unless someone on the forum can come up with something.
Old 04 Aug 2011, 06:04 pm
SKIM problem ???
Old 04 Aug 2011, 06:15 pm
Originally Posted by chan View Post
SKIM problem ???
The Sentry Key Immobilizer Module (SKIM) is part of the security system and kills the vehicle when a wrong key is used. There may be a problem with your key or the chip reader in the ignition switch. This is something the dealer will need to determine for sure. This code will also be set if someone actually tried to steal the vehicle.
Old 04 Aug 2011, 07:08 pm
I have 2 keys , 1 in the alarm box for REMOTE START and the one Im using . I can switch them out or just disconnect alarm since it has a kill switch .
Would be funny if thats it
Old 06 Aug 2011, 07:25 pm
Been tinkering around here and there on the car,, if I remove the battery terminals for a min or 2 then replace them she starts right up then about a minute later she shuts off . I can do it all day long . Thanks for the help Crewzin but I think its time to visit the Chrysler dealer
07 Cruiser Wont Start! 07fastptloser General PT Cruiser Discussions 1 15 Feb 2011 06:52 am
2004 PT CRUISER wont start margarcia1028 Tech & Performance Forum 1 22 Jun 2010 07:43 pm
help my baby blue (pt cruiser)wont start!!!! pttapp Tech & Performance Forum 2 12 Apr 2010 02:53 pm
2004 PT Cruiser Wont Start brian_jill General PT Cruiser Discussions 12 18 Feb 2010 01:20 pm
01 PT cruiser wont start.. EvilWRX General PT Cruiser Discussions 1 12 Feb 2007 02:35 pm
