afe cold air intake
Old 03 Aug 2011, 08:50 am
mattsptgt's Avatar
Default afe cold air intake
Any one know how good are intakes are because I just bought one and its getting put on today
Old 03 Aug 2011, 09:49 am
Default Re: afe cold air intake
If you have a turbo, you'll still be sucking a lot of hot air so you are better of with your modified factory air box and a K&N drop in filter You only gonna get the intake look and sound, no power gain...maybe the opposite
Old 03 Aug 2011, 12:18 pm
mattsptgt's Avatar
I beg to differ the air box mod is a joke And the stock one sucks the one I got has a heat sheld and I'm going to angle it to pull out the finder well.
Old 03 Aug 2011, 12:20 pm
mattsptgt's Avatar
Quick question does your stage one let I flat foot shift
Old 03 Aug 2011, 01:17 pm
If I need to shift fast, YES I always flat foot it with no problems....I never heard an Stage 1 not letting you do that.... Are you 5 speed, right?
And about that intake, I know a LOT of guys running 300+ WHP on their GTs and they ALL have the modified OEM air box with hard pipes and K&N drop in... They already tried the "cold air intakes" at the dyno and they saw a drop on HP when you use them.....
So the conclusion is that YOU WILL LOOSE hp because you are still sucking HOT air from the engine.
Old 03 Aug 2011, 01:47 pm
mattsptgt's Avatar
Well I don't see how it sucks more are but oh well and do u know if the dsp lets u flat foot shift
Old 03 Aug 2011, 02:17 pm
soonercruiser's Avatar
Cool Re: afe cold air intake
Beg to differ, with your "beg to differ".
ON my 3rd PT, this 2011 Couture, my bad knees had me go back the auto tranny.
And, I was tired to emptying the wallet for premium for the turbo.
So, as shown in a past post, I did the air box mod with a few tweeks.
-foam seal the larger intake tube to wheel well opening.
-made small "screened" opening in fender flap directly below opening in fender.
-Has a somewhat better pedal response; simiar to the AirRaid intake system in the na soonercruiser. THis should translate into a mile or two more per gallon highway.
-Gas mileage is yet to be tested.
-does give you a "litte growl" like the AirRaid
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 03 Aug 2011, 02:56 pm
Here is only 15 cents more per gallon...so about $2 more at the pump
Old 03 Aug 2011, 03:08 pm
That "cold air intake" will suck air from the place that is easy to suck...for example between the hood and your intake,or behind the battery, or around the pipe that goes to the turbo, etc because it will NEVER seal it completely.
I can always flat foot shift with any car. Why it doesn't let you do it?
Old 03 Aug 2011, 03:22 pm
You are wrong. This topic has been going for years, but I guess you missed it. If it is not enclosed you suck hot air. If you suck hot air you lose 1 hp for every ten degrees of hot air added. You also lose torque. All of this has been proven on the dyno.
AFE Cold Air Intake sCrod3s Tech & Performance Forum 14 01 Nov 2013 10:26 pm
Cold Air Intake - Please look SlowwCory Tech & Performance Forum 4 19 Aug 2009 07:31 pm
Cold Air Intake..? morrises Tech & Performance Forum 11 15 Jun 2008 01:20 am
Cold Air Intake mikeyram Tech & Performance Forum 7 29 Jul 2005 08:25 pm
Cold Air Intake CREWZIN Tech & Performance Forum 11 25 Dec 2001 01:50 pm
