04 PT CODES?? NEW PC..
Old 06 Aug 2011, 12:32 pm
Default 04 PT CODES?? NEW PC..
ok befor i could not get any codes odd the dash not even the DONE after do in the key deal..car was blowin the ASO fuse ..replaced the crank pos sensor,,battery,,fuel pump,,
now it starts up but still kinds flutters and sometime if you let it idle it will die?
soo nw im gettin codes with the new PC :],,,but my book dont show what it is?
first code is
P2305
next code is
P0522
one is the oil pressure switch?? right? and the first one is not in the book?
goin to get a hand help scanner and see if that will show more?
any help would be great? thanks I an"t givin up this bitch is gonna run if I have to drop a small bock in it..
Old 06 Aug 2011, 12:50 pm
Default Re: 04 PT CODES?? NEW PC..
local parts store said the P2305 code was the IGN COIL B ??
and agreed the the PO522 was the oil pressure switch..
new coil $65,,,any thought on this befor i go drop $$...
I foun dthe post with all the codes but still dont see the P2305 code listed??
Old 06 Aug 2011, 03:43 pm
The code list is old and doesn't have all of them.
Before buying a new coil, I'd check your plugs for spark. Coil B (or #2) fires spark plugs 2 and 3 but check them all for good spark.
Also found this in a search....
HOW TO REPAIR FAULT COE P2305 PT CRUISER - JustAnswer
Old 06 Aug 2011, 04:35 pm
thanks man. igot a new coil coming and replacing the sending unit too..i"ll check that cap if this dont fix it..the part about the bad ground ?? humm been all overr this thing checking grounds and wires,,i"ll let you know tomorrow nite what happens,,thanks for your help
Codes? BladeRunner Tech & Performance Forum 4 12 Apr 2011 10:07 pm
TOO MANY CODES!!! Nonie Tech & Performance Forum 13 20 Mar 2011 12:21 am
Codes, Codes, everywhere there's Codes Neen Tech & Performance Forum 6 21 Nov 2008 07:59 pm
No Codes?? BB General PT Cruiser Discussions 2 13 Aug 2005 08:25 pm
obd codes camarillogolfer General Turbo Discussions 5 06 Aug 2004 11:10 am
