Who uses an aftermarket fan.
Old 06 Aug 2011, 10:03 pm
Default Who uses an aftermarket fan.
After searching for about an hour, I decided to ask whick of you have installed an aftermarket fan into you PT.
I need the fan size and information on how you wired it.
2001 PT Cruiser, Silver, Base, 2.4 ltr.
Old 07 Aug 2011, 05:40 am
chigger_ns's Avatar
Default Re: Who uses an aftermarket fan.
I bought one from NAPA. I bought the shroud and all.
I had to undo the top of the rad support I think to do it.
You can also just buy the fan motor. Its way cheaper.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 07 Aug 2011, 07:08 am
Are you talking about an after market fan that's completely different from the OEM fan, or just a replacement fan from an after market source?
Since your saying you need the fan size and wiring instructions, I take it you mean something different than the OEM. Why? The OEM fan does a perfect job of keeping everything cool is both speeds are working. Like chigger_ns just said, you can by just a new motor, or you can actually fix the old motor or eBay sells the whole fan and support shroud for under $100.
Old 07 Aug 2011, 02:25 pm
I purchased a car that had been wrecked in the front. Radiator and fan were destroyed. Replaced the Rad and need a fan, figured that if there were an aftermarket unit with better cfm I would get it.
Old 07 Aug 2011, 02:49 pm
OK, but like I said, the OEM fan for under a hundred dollars with the shroud does a great job if it's working properly.
If you search on eBay for "pt cruiser fan" it comes up with all the fans for different years and some after market ones also.
Aftermarket Alarm Eccentric0ne Sound and Security Forum 0 03 Feb 2010 09:37 pm
06 Aftermarket 1lowufo Exterior Accessories Forum 2 29 Jan 2008 12:12 pm
Best Aftermarket Stereo? jimmmhare Interior Accessories Forum 6 17 May 2007 06:02 am
aftermarket WGA & BOV OurPTGT Turbo Performance 5 22 Oct 2004 10:17 am
Aftermarket Lettering CREWZIN Exterior Accessories Forum 7 03 Jun 2004 10:28 am
