Daylight funktion problems...
Old 07 Aug 2011, 03:08 am
Default Daylight funktion problems...
My 2007 Cruiser has a problem with the headlight when I to turn it on with the multi switch handel.. Its a car with a daylight module.
Problem is when i turn it on, that normaly in the evenings to get the, dashboard light, it is only the light in the driver side that works.. the wirering must be ok to the lamps, it works when I start the car both headligths works perfect. I have also tryed out a new Multiswitch arm, it was still the same problem..
Input would be nice
Old 07 Aug 2011, 05:42 am
SCBluePT's Avatar
Default Re: Daylight funktion problems...
Welcome to the forum.Have you tried changing the bulb to see if that works?
Old 07 Aug 2011, 07:21 am
Yes that was my first top of mind to do... the bulp works its a car where the light is on when I start the car. so the bulp, wiring shut be ok. its between the multiswitch and the bulp somthing is going wrong... thanks for input.
Old 07 Aug 2011, 07:39 am
SCBluePT's Avatar
I'm not sure then.Maybe someone else will be able to help.
Old 07 Aug 2011, 08:20 am
I take it your in Canada since the U.S. models don't have the DRL (Daytime Running Lights).
Since you've already tried the simple things like the bulb and a new Multi-function Switch (MFS), the only thing left to to trace down the wiring to the cluster connections.
Our repair manual don't have the wiring diagrams for the DRL's and only have a short paragraph to explain how they work.
Old 07 Aug 2011, 08:42 am
SCBluePT's Avatar
Yeah,that's why I asked about the bulb.Most people assume that because the DRL's work the headlights should work too,but the DRL's use the turn signal bulbs so they will work even if the headlight bulb is bad.
Old 07 Aug 2011, 09:10 am
Im just thinking, the DRL is working ok. when i turn on the car light works perfekt on both side as it shut, it is only when i try to turn the Multifunktion swich on, to low beam light posistion it wont work, high beam works ok.
Is there a seperat relay or somthing that controls the power to the lowbeam headlights?
Old 07 Aug 2011, 10:33 am
It's ALL done using the muti-function switch but you said you tried out a new switch.
Old 07 Aug 2011, 11:32 am
Yes this is checked, so i will try to find out how the system works when i turn on the manuel low beam setup with the Multi function switch. there must be a kind of relay or something that take over for the Daytimen running lights module..
thanks for all input...
Old 07 Aug 2011, 12:16 pm
Any one that know how to get a Canadian 2007 Wire Diagram on the headlight?
AC Problems I need help NeecieWilson Tech & Performance Forum 11 14 Aug 2010 05:14 am
Problems! PT17 Tech & Performance Forum 10 18 Sep 2008 06:11 am
my newest mods. NEW DAYLIGHT PICS CruiserDan Exterior Accessories Forum 10 27 Oct 2005 08:00 pm
More Sub Problems CHROMEDCRUISER Sound and Security Forum 7 17 Feb 2005 05:00 pm
Problems Oddcouple General PT Cruiser Discussions 1 17 Nov 2002 01:58 pm
