Reg fuel
Old 08 Aug 2011, 07:43 am
Question Reg fuel
What changes do you suggest for a 2006 2.4 Turbo to run on reg fuel?
Old 08 Aug 2011, 08:09 am
Default Re: Reg fuel
If is a GT, you can't use regular. If is turbo light you can use it with no problem.
Old 08 Aug 2011, 09:23 am
If it's a GT, or high-output turbo, the only change we could suggest would be to buy a PT without a turbo. The PT will run on regular, but good luck keeping it together over the long haul. You'll experience lots of engine issues after running on reg fuel for a while....
Old 08 Aug 2011, 11:09 am
Here is only 20 cents cheaper...so you'll be saving only $2.40 a fill up
Old 08 Aug 2011, 02:05 pm
soonercruiser's Avatar
Cool Re: Reg fuel
Look inside the fuel cover.
If it says"Premium Fuel Only"....do so!
Frank, aka SOONERCRUISER,
Old 08 Aug 2011, 05:11 pm
If you're going to run regular gas in your turbo, first you need to make sure you can. The instructions for insuring proper fuel usage are here:
I've not used these instructions myself, because I thought I had to use super only, so let us know how it goes...
Old 08 Aug 2011, 05:54 pm
Thanks guys...
Old 08 Aug 2011, 07:06 pm
carolinagirl's Avatar
Send a message via Yahoo to carolinagirl
in the owners manual I have says
2003 Limited Edition, Blue, Stock
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
Fuel spots under fuel door patbluecruiser The Detail Shop 2 15 Apr 2005 07:01 pm
Fuel RM General PT Cruiser Discussions 8 18 Feb 2004 10:18 pm
