ABS and trac control lites on
Old 09 Aug 2011, 04:36 pm
Question ABS and trac control lites on
Just put a new CV axle in the right front of my 2001 Cruiser,now I've got both the ABS light and traction control light on. Did I pop a code somehow? My scanner shows no codes present,but I think this would be the BCM and not ECM. How can I clear it? I just went out and did the key dance and it shows P1684. Driver 4,line 5. WTH?
Old 09 Aug 2011, 04:43 pm
Default Re: ABS and trac control lites on
Check connections and placement of the ABS sensor on that wheel and the toothed wheel it reads off of.
And I believe disconnecting the battery and stepping on brake to fully discharge will reset all codes - if you get it after, then problem persists.
Wheel sensors aren't that expensive if you damaged it doing axle.
trac control & abs light staying on in dash bobs turbo pt General PT Cruiser Discussions 13 22 Apr 2017 08:44 am
Trac control or ABS? sptanz General PT Cruiser Discussions 10 30 Apr 2012 11:07 am
Trac control system? BladeRunner Tech & Performance Forum 2 15 Dec 2010 07:01 pm
Trac control kicking off E brake alarm? sknight88 General Turbo Discussions 1 05 Jul 2008 08:03 pm
Trac control, wiper switches on center dash Espresso General PT Cruiser Discussions 6 04 Apr 2005 09:50 pm
