Timing belt time!!!
Old 09 Aug 2011, 09:45 pm
ROCKETMAN8060's Avatar
Default Timing belt time!!!
Well I went to my friend in the Chrysler dealership and guess what!!! My water pump has a leak so is time to do the timing belt! I really did'nt want to do this job now $$$$ but I have no choice!
This are the parts I got so far...
I got the Gates racing timing belt and Serpentine Belt also the Gates cam seals! Everything else I will go OEM!
Gates Racing Micro-V Serpentine Belt Chrysler PT Cruiser - K040345RB
ROCKETMAN8060
Old 09 Aug 2011, 11:12 pm
Default Re: Timing belt time!!!
With how much time it takes to just replace the belt you might as well replace the tensioner and idler pulley. I used Gates components when I replaced my timing belt about 2 years ago. The components were of high quality and I didn't have any problems since the replacement.
Good luck with your replacement. I found that the more you disconnect/remove from the engine, the more you will be able to move the engine to get the clearance you need.
PT Patriot
2002 Patriot Blue PT Cruiser Touring Edition
Old 09 Aug 2011, 11:19 pm
Did the guy give you an estimate for the labor yet?
Old 09 Aug 2011, 11:41 pm
Tomorrow he will call me with a quote
ROCKETMAN8060
Old 10 Aug 2011, 11:21 am
rcktpwrd's Avatar
I agree with PT Patriot, also replace the timing tensioner and idler. I would also replace the accessory belts and tensioner while it's all apart.
Joel
www.rcktpwrd.com
Old 10 Aug 2011, 12:28 pm
And I had them throw in a new thermostat while they were there....
Old 10 Aug 2011, 01:55 pm
I have order everything OEM from my friend in Chrysler! The belts are the racing kind! Also order a 180 deg thermostat! Im still waiting for the quote from my friend to see how everything is going to be!!!! So far is around $200 in parts!
ROCKETMAN8060
Old 10 Aug 2011, 02:20 pm
And I would change that center motor mount too...
Old 10 Aug 2011, 02:32 pm
Yeah, *really* wish I'd done that when I had the head off. *sigh*
Old 10 Aug 2011, 03:20 pm
Well the quote for the job is $450.00 with out parts! Good?
ROCKETMAN8060
Timing belt tensioner is giving me a hard time damilleniumboy Tech & Performance Forum 5 24 Nov 2011 08:57 am
Time for timing belt change kevinmellett General PT Cruiser Discussions 14 22 Feb 2011 10:33 pm
Time For Timing Belt BB General Turbo Discussions 5 16 Dec 2009 05:05 pm
