At wit's end-2007 non-turbo-A/C problem
Old 10 Aug 2011, 08:55 am
Default At wit's end-2007 non-turbo-A/C problem
I am dealing with a 2007, non-turbo with an air conditioning problem. We have been told by the "stealer" this is a compressor problem which they can fix for $1500. Other independent Mechanics say it is a switch, sensor or wiring problem that could take many, many hours to trace.
I filled the system to the correct low-side pressure a couple of days ago. It cooled just fine. A few hours later my son-in-law tried it out. After starting the car and turning on the A/C; he started hearing a hissing or gas venting sound and the cooling gradually went away.
An on-line (non-MOPAR) A/C expert said it is a bad sensor that is not telling the ECM to turn the fans on which in-turn raises the pressure to the point that the relief valve pops open. We have also had this diagnosis from another, local, semi-pro technician.
Could this be the elusive "high-pressure" swith that is said to be located on the compressor or near by in the high pressure line? I think I have found the replacement part but I want to be absolutly sure of the location before I order the part and take it to the guy to install.
I am assuming that it is not the low-pressure cycling switch located on the dryer near the low pressure port.
Old 15 Aug 2011, 03:29 pm
Default Re: At wit's end-2007 non-turbo-A/C problem
I finally got a chance to inspect my compressor and to my surprise I found a "pressure relief valve". It is located on the bottom of the back plate of the compressor. It appears to me to be a "burst disc" type of pressure relief. I didn't remove it to confirm. Burst discs are one time use only. If it has "burst" it must be replaced. The parts manual does not show the valve as a separate part from the compressor.
You mention that you filled the system to the correct low side pressure. Maybe your 2007 is different, but most automobile A/C systems (including my 2002 PT) are charged by refrigerant weight, not by pressure. Pressure/temperature charts in the FSM are for checking the system. If the check shows incorrect level of refrigerant, the standard procedure is to recover the refrigerant, evacuate the sytem and then fill with the specified weight of refrigerant.
Other information that may be helpful:
1. The low pressure switch is for cycling the compressor when the heat load is low.
2. The high pressure switch is to protect the compressor from high discharge pressure.
3. A non-functioning low speed fan will cause high system pressures at idle.
If the relief valve is venting it is either broken or the high pressure switch is broken. The reasons for high discharge pressure are: (1) restriction on the discharge or liquid line, (2) too much refrigerant and (3) non-functioning low speed fan.
PT Patriot
2002 Patriot Blue PT Cruiser Touring Edition
Old 15 Aug 2011, 03:49 pm
...and the answer IS .......drum roll..........the fan !!!!!
It's the number one cause for warm air from the A/C system and for the discharge out of the compressor.
Do this: Let everything get cold. Turn the engine on, turn the A/C on. Go to the engine and see if the fan is running. It's supposed to come on as soon as the A/C is turned on no matter how cold/hot the engine is. If the fan isn't running, replace it.
P.S. Don't forget that your system has been dispersing the R134a into the atmosphere when the pressure built up so you might have to recharge it again when you replace the fan.
Old 15 Aug 2011, 04:05 pm
GhostFlyer's Avatar
Just for the heck of it I paid attention when I started my car ( 2006 touring na ) and the fan comes on as soon as the car starts if the AC is on or not. I have only heard the fan running at one speed. I guess when I get some time I will have to do some checking.
2006 Touring, Inferno Red, Light gray interior, Pretty much stock for now.
Purchase date 7/29/11 69K miles
Old 16 Aug 2011, 02:47 pm
mdfrodolives's Avatar
It's that high speed not working that gets ya!
Tim
Old 22 Aug 2011, 12:15 pm
Is the fan bad even though it kicks on after car is running a while?
Old 22 Aug 2011, 02:32 pm
bigdee,
The fan won't come on till the temperature raises to a certain point, that's normal. IF, the A/C is turned on at any time, the fan should also kick on.
Old 22 Aug 2011, 03:33 pm
When I first start car and put a/c on, a/c blows hot. At this point, cooling fan is NOT on. After temp gauge in cab gets to about half way, cooling fan kicks on. At this point, a/c is still blowing hot. I could change out fan, but do you think that's the problem?
Old 22 Aug 2011, 04:01 pm
If it's not THE problem, it's certainly A problem. First you need to find out if both fan speeds are working, then IF they are, you need to find out why it's not coming on when the A/C is turned on.
Old 23 Aug 2011, 11:53 am
From BigDee's other posts (2007 pt cruiser a/c blowing hot) the compressor is not engaging. You need to determine why the compressor is not engaging before worrying about the fan. I put some more tips on your other post.
PT Patriot
Tags
a/c, air conditioning, pressure, sensor, switch
Horn Problem 2007 Cruiser crandon71 General PT Cruiser Discussions 8 15 Jul 2017 02:22 pm
Turn Signal Problem 2007 Pt Twinb2 General PT Cruiser Discussions 4 26 Sep 2012 02:46 pm
1ST SMALL PROBLEM W/ 2007 PT VARELAGIRL Tech & Performance Forum 4 11 Nov 2010 05:52 pm
2007 Pt with a transmission problem Sam31 Tech & Performance Forum 10 10 Nov 2010 09:28 am
