Drive Belt (PS/AC) Belt
Old 10 Aug 2011, 11:08 am
Default Drive Belt (PS/AC) Belt
Hey folks.
Tried to replace my drive belt last night, and the new belt is too short. Double checked with Auto Zone and said it was the belt called (Dayco 560)for, but it's 2" short. Anyone else with this same problem, and more importantly, anyone with a solution?
Thanks again.
Old 10 Aug 2011, 11:42 am
Default Re: Drive Belt (PS/AC) Belt
Try another store or brand. unless yours got really stretched
Old 10 Aug 2011, 01:46 pm
rcktpwrd's Avatar
what year is your PT? I think somewhere along the line the belts changed...
I looked at AutoZone's web site and they list something different for an '01 compared to an '03
Joel
www.rcktpwrd.com
Old 10 Aug 2011, 04:53 pm
TN,
Make sure the number on the belt is the same on the box!!!
The same thing happened to me and it turned out autozone had the wrong belt in the box!!
Seth
Old 10 Aug 2011, 05:05 pm
Mine is an '02. Took the belt back to AZ just to confirm that the size was correct. The 56" belt will no freakin' way fit. Was concerned that maybe the tension adjustment arm was replaced wrong or in the wrong position, don't know, just grasping at straws
Old 10 Aug 2011, 06:38 pm
rockauto.com shows 56" belts for '01-'02 and 55" belts for '03+. I put a Gates K040560 on my '01 about a month ago without issue. Maybe you don't have the tensioner compressed all the way? Did you compare the belt that came off with the belt you're trying to put on? How much longer is yours than the new one?
Old 10 Aug 2011, 09:43 pm
Finally found a Goodyear gator belt 4 rib 57" that fit. Still cannot figure why the std. belt would not fit. The old one measured 57.5". Quad checked the belt routing, the tension pully only has about 2" of travel, have a feeling the problem may well lie there
Old 10 Aug 2011, 10:53 pm
That's what I always use on my cars and never had a problem ....and sorry but I forgot to recommend it to you
Old 11 Aug 2011, 12:42 am
Is it possible you are routing it wrong? When I first replaced mine I couldn't figure out how to make it fit - it was either slightly too short or quite a bit too long. After checking the manual and seeing the belt routing, it made sense and worked perfectly.
Old 11 Aug 2011, 09:20 am
Did you look at the markings on the old belt to see what it was? If it wasn't a 56" perhaps a previous AC or PS repair ended up with a slightly larger pulley. That is very unlikely. More likely is the new 56" is a snug fit and needs the tensioner at the extreme end of its travel. This was the case when I replaced the belt on my 2002 a while ago. The 56" seemed a bit snug but it went on.
Going with a 57" when the application calls for a 56" will give you less life out of the belt. Belts stretch over time. If the old one you replaced was 57.5 inches, your new 57" will only give you 0.5" of stretch before giving the same performance as your old one.
It is also possible that the 56" you got just happened to be at the short end of the manufacturing tolerance. You could compare all of the 56" belts at the store and get the longest one.
PT Patriot
2002 Patriot Blue PT Cruiser Touring Edition
Drive Belt Info demon666 Tech & Performance Forum 9 11 Apr 2010 11:29 pm
New Drive Belt Still Squealing - Now What? falconut Tech & Performance Forum 5 25 Mar 2009 04:18 pm
drive belt replacement boilerhog Tech & Performance Forum 1 29 Nov 2008 07:09 pm
drive belt help tomctomc General PT Cruiser Discussions 5 13 Aug 2005 10:04 pm
Drive belt question turbomangt General Turbo Discussions 3 19 Apr 2005 08:39 am
