2005 Fan middle pin problem
Old 10 Aug 2011, 07:31 pm
Unhappy 2005 Fan middle pin problem
My Pt cruiser started to overheat a couple of weeks the fan seems to be the problem it doesn’t turn on, when it starts to overheat I just move the wire close to the fan it seems to be working I unplugged the wire and the middle pin is broken so I change the fan, I test drive it to see if its fix and the same problem it started to overheat and the same middle pin to the fan seems to be the problem, I have to replace the fan again no problem is under warranty but where does this ground comes from I checked the fuses and they are fine I swap the horn relay to the fan and the horn works so any suggestions?????
Old 10 Aug 2011, 08:14 pm
Default Re: 2005 Fan middle pin problem
Are you asking for a wiring diagram? If so, PM me, too large to post here.
Help with Middle pass side motor mount Leannaluv Tech & Performance Forum 15 08 Sep 2014 02:07 am
2005 convertible problem DC1327 PT Cruiser Convertible Forum 6 21 Dec 2013 11:26 pm
Middle mount passenger side questions Leannaluv Tech & Performance Forum 4 24 May 2011 10:24 pm
2005 Horn problem crzn45 Sound and Security Forum 1 11 Dec 2010 04:25 am
2005 turn signal problem ricksterw General PT Cruiser Discussions 7 18 Feb 2010 05:59 pm
