2004 Cruiser
Old 12 Aug 2011, 08:42 am
Unhappy 2004 Cruiser
I have a 04 Cruiser with the following problem:
1) Runs great in park or neutral.
2) Put it in any grear and the engine will lope, with no get up and go !?
I would love to have some help with this matter, I just don't know where to go next.....thanks
Old 12 Aug 2011, 08:47 am
Default Re: 2004 Cruiser
I would start with plugs and wires - get a name brand of wires - Belden, autolite, etc. - do not use stock wires - they are crap - the champion spark plugs are fine - gap at 0.040.
When you go in gear, load on engine increases and poor spark is more prevalent than at idle.
It can't hurt.
Old 12 Aug 2011, 11:41 am
Probably not as likely as plugs and wires, but you should also check the engine ground. I had a much older car ('79) that acted exactly like you describe and the problem was a poot engine ground.
The main engine ground on the PT is attached to one of starter bolts.
PT Patriot
2002 Patriot Blue PT Cruiser Touring Edition
Old 12 Aug 2011, 05:35 pm
Have you tried pulling error codes yet?
Old 12 Aug 2011, 06:59 pm
Yes I have, and there is no faults...thanks
Old 13 Aug 2011, 12:30 am
What happens if you shift into 2? Does that change the symptoms. Sounds to me like either there is an electronics problem between the transmission computer and the engine computer, or it's not downshifting into 1st gear when you put it in drive... it's sticking in a higher gear, which results in bad performance. When you are going, say, 15mph, what does the tachometer read?
Old 13 Aug 2011, 12:42 am
mdfrodolives's Avatar
I wonder if it's in "limp mode"?
Tim
Old 13 Aug 2011, 12:59 am
More details!!!
Have you done anything yet? When was the last spark plug change? Air cleaner? Wires? PCV valve, etc.
Did it suddenly start acting up or has this been getting worse over time?
If you look under the hood when the engine is loping, is the engine bouncing around?
2004 pt cruiser dream cruiser series 3 LNBNDN General PT Cruiser Discussions 5 22 Oct 2012 07:55 am
2004 pt cruiser watsonmv Tech & Performance Forum 7 15 Dec 2011 09:05 pm
2004 PT CRUISER help demon666 General PT Cruiser Discussions 2 22 Jul 2009 12:24 pm
PT Cruiser-2004 karanoble Tech & Performance Forum 1 13 Jan 2009 10:42 am
for those with a 2004 n/a Cruiser . . . legion Sound and Security Forum 1 16 Nov 2004 09:37 pm
