automatictranny direct drive
Old 12 Aug 2011, 01:27 pm
Default automatictranny direct drive
02 Pt Touring limited edition 2.4dohc At,190k. problem started odd surge at idle while in drive, simular when fuel pump failed. Other morning started car and put in gear and it surges forward and stalls. Start again solution more fuel squeals tire and stalls. Best desciption is torque converter locked solid providing direct drive . can get car moving but if you brake just like braking a manual trans with out clutch it stalls . i know most elect. trans have torque converter lock up soleniods searched found referances to trans. soleniod but most refer to code or leak issue, can this unit cause such a problem ? bought used in 03 60k trans changed. (warrantee third trans.) went in 90k have had no problem trans. related until this. Any help would be greatly appreceited. All work performed at home.
kevin
Old 12 Aug 2011, 05:58 pm
Default Re: automatictranny direct drive
kevin
Unfortunately I can only tell you that when my wifes solenoid pack failed, it still drove in limp mode. I don't think the solenoid actually runs the TCC, but I'm probably wrong.
Anyone know if the TCC control is separate from the solenoid pack? Any way to pull the connector off to prevent TCC lockup? I just haven't pulled one of these out yet, I can tell you for sure on an 89 firebird 700r4 that it has its own connector.
Old 13 Aug 2011, 09:10 am
thank you for the response . i have a 700r4 sitting on garage floor 4 pin connector . can anyone direct me to a trans. service manual or a wiring schematic and or diagram i'll take it from there. thank a million for any help it is greatly appreciated. I am familiar with repairs on pt-brakes(f+r) sway links and bushings (f+r)shocks,exhaust(mid pipe)Alt.,timing belt and idler pulley, water pump . F. struts, control arms and wheel bearings, intack manifold gasket with tune upfirst time tackling trans. I hope its a out side electrical problem!
P. S. also have 07 pt with 70k time for front end work any suggestion for bushings that will hold up a little better than Auto zone new part free is great but you still have to put the time in quality durability are not overated .
Old 13 Aug 2011, 10:47 am
Thank You -CREWZIN,LUCKY_16,AND CHROMENUT . Manual under feedback and support : verified clean copy excellent I'll update when i have fresh news. Still welcome all suggestions.
Direct connection iPhone 3G PurplePTGirl Sound and Security Forum 1 08 Dec 2009 04:31 pm
FS: Mopar iPod Adapter Kit 82209617AC - Direct Connection jimmirehman Classifieds: For Sale/Trade 1 17 Jun 2008 10:41 am
Mopar iPod Kit 82209617 - Direct connection jimmirehman Sound and Security Forum 0 16 Feb 2008 04:52 pm
17" Factory Chromes on EBAY or buy direct PTTIM Classifieds: For Sale/Trade 0 16 Jul 2006 11:56 pm
