Odometer fault codes are inaccurate?
Old 15 Aug 2011, 01:45 pm
Default Odometer fault codes are inaccurate?
We have an '02, and the Check Engine light has been on for a while now. We've not noticed even the slightest change in operation. One shop said the error code related to a bad ECM, and the dealer would have to replace it.
I read that you could get the fault code on the odometer by cycling the key back and forth within five seconds, and I did that. Problem is, the code, 1601, as stated by the dealer, is a "ghost" code and absolutely meaningless. I was told that the codes displayed on the odometer are invariably inaccurate. Is that true?
Anyway, it's an '02 with just 54K on it. Does the ECM typically fail around 9 years?
Old 15 Aug 2011, 01:54 pm
Default Re: Odometer fault codes are inaccurate?
I've never seen an ECM (more accurately PCM - powertrain control module) actually fail outright.
P1601 Serial Comm. Problem With Device 1
another place has it as:
P1601 ECM/TCM Serial communication error
No clue what that means. All codes mean "something", they didn't engineer a vehicle that just decided one day to report an error that meant nothing at all. Even the oft-reported P1684 (which is the battery has been disconnected in the past 50 starts) - means "something".
To me at first glance - it means the transmission module and the engine module aren't communicating. It could be as simple as that it isn't plugged in, a bad wire somewhere, bad connector, bad TCM OR bad ECM (in that the serial transceivers used to communicate has failed).
The only time there is a difference in what is displayed in the OD, and a scantool - is if one of those codes is P0700. That indicates a "transmission control module has stored codes" - as the TCM has a different code set. Those aren't displayed in the OD. No codes exist unless you have a P0700 first. Invariably what is displayed on the OD, are what the PCM has stored as trouble codes.
One thing to try - remove the negative terminal connector on the battery. Wait a while (15 minutes or mor) - and reconnect. This clears any trouble codes. If the code persists, it has just been set.
Old 15 Aug 2011, 02:24 pm
I think you guys mean P0601 instead of 1601.....................................
P0601 - PCM internal controller failure.
When monitored = ignition key on.
Set condition = internal checksum for software failed, does not match calculated value.
Possible causes = PCM (no other causes)
Test = none. The PCM is reporting internal errors and must be replaced.
By all means get a second opinion on this, perhaps through the DC dealer
Old 15 Aug 2011, 03:00 pm
rcktpwrd's Avatar
A few years ago the check engine light came on in mine, did the key dance and got a code that said the PCM had an internal fault. I don't remember what code it was. The car ran perfectly normal but it would not pass the state emissions test because the light was on. The only fix was to replace the PCM, fortunately for me the car was still covered by the Federal emissions warranty so it was replaced at no cost to me.
Joel
www.rcktpwrd.com
Fault Codes sscanlan Tech & Performance Forum 11 29 Sep 2010 09:53 pm
Won't Start---Can't get fault codes patspt Turbo Performance 8 01 Jun 2010 04:47 pm
Clearing fault codes thender Tech & Performance Forum 2 08 Nov 2009 08:00 pm
How to retrieve fault codes. CREWZIN Tech & Performance Forum 0 11 Jul 2009 09:52 am
Whats the difference between key trouble codes vs odometer ones? sknight88 Tech & Performance Forum 10 22 Jun 2008 04:56 pm
