wich cv joints should i order
Old 15 Aug 2011, 05:05 pm
Default wich cv joints should i order
i have a 2002 dream cruiser. car needs new driveshaft/ cv joint, but i dont know wich one to order . i ve searched ebay, but when i search by model it says that part is not compatible even if it says that part is for a 2002. thanks for your help guys.
Old 15 Aug 2011, 05:23 pm
Default Re: wich cv joints should i order
Try rockauto.com
Old 15 Aug 2011, 06:13 pm
In fixing my '02 a few weeks ago, I ran into this problem. It derived from the fact that Chrysler switched from 33mm wheel bearings to 39mm that model year. Do you know which you have? I ended up having to buy a remanufactured axle to fit my new 33mm bearing/hub assembly. If you get one of the new axles designed to fit the 39mm bearing/hub, the shaft is too long, and it won't tighten down without adding spacers. I didn't want to do that. There is a thread I started on lower control arms, where these guys helped me out, that goes into it more. If you have the 33mm bearings, you might have to look up parts for an '01.
2002 Limited Edition, 5 speed
Old 16 Aug 2011, 03:44 pm
thanks for the reply . im not sure of the bearing specs. i went to rock auto and found several choices . will this fit, and if so wich bearing should i use?
Product Detail
Old 16 Aug 2011, 05:16 pm
You use whatever bearing your car already has. And you won't know that until you get it apart. If I had to guess, the axle you show is for a 39mm bearing. I bought one like that and had to take it back. But 39mm is suppose to be more common, so you might be ok.
Old 17 Aug 2011, 03:53 pm
i believe the bearing is shot since it makes a loud humm. i replaced wheel bearing was shot too.
Help! How do you get ball joints back into assembly? Neen Wheels, Tires, Suspension 2 27 Mar 2011 01:39 pm
Ball Joints android Wheels, Tires, Suspension 1 12 Nov 2004 01:48 am
anyone order one yet?? bobs turbo pt PT Cruiser Convertible Forum 0 31 Dec 2003 04:47 pm
In What Order? PianT General Turbo Discussions 13 16 Sep 2003 03:05 pm
on order sbcruzn General PT Cruiser Discussions 9 26 Feb 2003 11:01 am
