Engine Light
Old 16 Aug 2011, 11:13 am
Default Engine Light
OK guys and guyetes...several motnths ago my engine light came on. being old school the first thing I checked was the oil level..it was low so I added a quart and low and behold the light went out. Satisfied with myself I told my mechanic . He said that the light has nothing to do with oil level. I looked in the owners manual and found out that he was right...hmmm. Just last week the same light came on..checked the oil and it was low again...added a quart and the light went out ...again...so what is going on...any ideas.....wires crossed? '06 PT with 52,000 miles and no problems before.
Old 16 Aug 2011, 11:22 am
Default Re: Engine Light
Robbie, or is it Bobbie?
I moved your post over to the TECH section as you had attached you question to the GAME thread.
You said the engine light came on. If it was the engine light and not the oil light, it means one of the sensors detected something it didn't like. When it does this it sets a fault code in the computer and turns on that engine light. So, you need to find out what the computer code is saying.
click here and follow the instructions to find a fault code on your odometer dial. The code will look something like this. P0340 (just different numbers).
How to retrieve fault codes.
As far as loosing oil. Are you seeing any drips/puddles on the ground? You can check the coolant to see if there's any signs of oil getting into it and look for any tel-tale signs of white smoke out the tailpipe.
Old 16 Aug 2011, 12:24 pm
How's it been running? Any "missing" at idle or "stumbling" when you give it gas?
Sometimes engine light comes on - like for a misfire - then goes out when problem no longer exists.
As to oil consumption, aside from leaks, the PCV valve....
read thsi:
Oil Consumption Problem Solved!
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Car Sometimes won't start (oil pressure light & Engine Light) gerardio Tech & Performance Forum 6 18 Jul 2008 08:22 am
