PT is acting weird when A/C is on
Old 21 Aug 2011, 12:50 am
Default PT is acting weird when A/C is on
My wife's '04 PT is having A/C problem. Every time the car sits for a period of time and then started with A/C on, RPM's will fluctuate and drop below 500 and the car would stall. Has anyone else experienced this problem before?
Old 21 Aug 2011, 01:42 am
Kawizx9r's Avatar
Default Re: PT is acting weird when A/C is on
Remove the IAC Valve (it's the black thing connected to the upper portion of your throttle body closest to your firewall) and clean it.
Are you getting any engine codes at all?
Kawi is a friggin genius!
Old 21 Aug 2011, 11:29 am
Thanks! I'll try that. There are no codes.
Old 21 Aug 2011, 04:11 pm
Is the radiator fan working ok?
Old 21 Aug 2011, 05:12 pm
Yes, it works fine.
Old 21 Aug 2011, 05:40 pm
Both speeds? Low and high?
Old 21 Aug 2011, 06:07 pm
Yes, the fan works fine both speeds.
Old 21 Aug 2011, 06:22 pm
I have no idea then
Old 21 Aug 2011, 06:57 pm
No worries. Thanks anyway.
Old 21 Aug 2011, 09:21 pm
Kawizx9r's Avatar
Did my suggestion work?
Cleaning or replacing it (with an OEM-type) should fix it.
You didn't say anything about the car overheating so I'm pretty sure it's the IAC valve.
AC acting funny!!! Making my PT jumpy!! StephHammerberg General PT Cruiser Discussions 11 05 Sep 2011 01:34 pm
Sunroof acting weird Franksredpt General PT Cruiser Discussions 2 10 Apr 2009 11:12 pm
So my Trans MIGHT be acting up? Cathy06PT Tech & Performance Forum 6 11 Nov 2008 10:57 am
Dash acting weird Nikkortim General PT Cruiser Discussions 8 04 Sep 2005 06:30 pm
My PT is acting up at 68K miles (VERY BAD) Ctown General PT Cruiser Discussions 2 11 Mar 2005 11:10 am
