04 PT, jerking when accelerating
  • 1 Post By WolfmanG
Closed Thread
Old 21 Aug 2011, 09:30 am
Unhappy 04 PT, jerking when accelerating
Hi! I am new here, and have already read several posts with problems that sound similar, but I figured I'd explain mine. We just bought a 04 PT with 106000 miles on it, it had hail damage to the body and was a great deal. Seemed fine until we got it home, and then suddenly on pulling out and accelerating, it started jerking. It was just like when someone doesn't know how to drive a stick, it jerked, seemed to calm when you let off the gas, but sometimes it would just rev when you pushed the gas but not go. The rpms were really high for how slow we were going. Tried putting it in 3rd, did the same thing. Then, a few hours later, got in it, and no sign of trouble. Of course it did it again later, along with a hot/burn smell when you stepped out of the car. Any ideas? I've seen several people suggest plugs and wires, and also sensors of some kind.
thank you so much for any advice!
Christina
Old 21 Aug 2011, 06:43 pm
WolfmanG's Avatar
Default Re: 04 PT, jerking when accelerating
Christina
Hey Christina, sorry to hear about your troubles. Is your check engine like coming on? if so you might want to do the key dance, which is, Turn off the car, then turn the key to the acc position three times, then leave it on, on the third time. The acc position is the last position the key is in before the car turns on. So do it like this: on-off-on-off-on do it with in 5 second. look at your cluster and watch for any codes that come up. make sure and write them down so you can come back to this forum and look up the codes.
Honestly it kinda sounds like your camshaft position sensor, but we really wont know until you get the codes. Good luck
-Danny Wolfman G
Old 22 Aug 2011, 07:51 pm
Thank you so much! Got two codes, forgive me but I can't remember them. We wrote them down and my husband took it to a mechanic today, got it all fixed up, and it seems to be running like a top!
Old 22 Aug 2011, 08:41 pm
WolfmanG's Avatar
That's good i'm glad she's running again. I just hope that if the mechanic had to change any sensors then he changed them with Mopar/OEM sensors. Our baby's don't like autozone parts, they last a few weeks and then you gotta replace it again.
-Danny Wolfman G
Old 05 Oct 2011, 07:50 am
I'm having the same issue with my PT. What did the mech. change??? I'm getting no codes though.
Anything would be helpful.
Old 06 Apr 2013, 02:00 pm
I'm having the same problem with my 07 pt cruiser. It shows a different code each time someone works on it. At first it was the cam sensor, changed that, still doing the jerking. Changed the crank sensor, still doing the jerking. Now I'm sitting at the Chrysler dealership waiting to see what the next code will be. It starts acting up as soon as I leave the mechanic. Any advise would be appreciated. Thanks!
Old 08 Feb 2014, 10:53 pm
Hi, I currently have this same problem of jerking while accelerating. Thanks to this website I discovered the "key trick" and found that one of two check engine issues is P0340 - the camshaft position sensor.
I recently removed my battery and recharged it, it had drained because of a weak connection on the positive terminal. I'm guessing this removal of the battery caused the fault with the camshaft sensor because the jerking started happening immediately afterwards. Will the camshaft position sensor need to be replaced?
Old 08 Feb 2014, 10:58 pm
If the jerking comes back, yes. Get a Mopar sensor, not a mystery brand.
Old 08 Feb 2014, 11:42 pm
Originally Posted by NitroPT View Post
The key dance is NOT an accurate way to view DTC's or pending DTC's. It is very generic. You should get your PT scanned properly with a scan tool at the diagnostic port. Write down all the codes if any and then clear them out. Then do at least one full engine cycle and re-check for codes before start buying parts and replacing parts.
This is a VERY bad idea! In this case properly scanning the OBDII port and accessing DTC's would be the first start in correcting the problem. NOT just jumping to the conclusion that a new replaced part is defective!
He did not replace any part - reading comprehension is obviously not your strong point.
Old 08 Feb 2014, 11:45 pm
you should re-read my response as well. It seems that we have reading comprehension in common.
If you read "In this case properly scanning the OBDII port and accessing DTC's would be the first start in correcting the problem."
Closed Thread
Tags
accelerate, acceleration, hot, jerk, jerking
My car started jerking! helene Tech & Performance Forum 14 30 Oct 2011 09:58 pm
vibration when first accelerating PurpleMoo41 Turbo Wheels/Suspension/Handling 7 05 Aug 2011 06:24 pm
Shudder while accelerating from 20-30mph cnjvh General PT Cruiser Discussions 9 21 Dec 2010 01:46 pm
Brake light comes on when accelerating kmancrx Tech & Performance Forum 11 02 Dec 2009 09:33 pm
PT Cruiser studdering/jerking oscar514 Tech & Performance Forum 4 28 Feb 2009 11:47 pm
