2007 pt cruiser a/c blowing hot
Old 22 Aug 2011, 11:06 am
Default 2007 pt cruiser a/c blowing hot
When I first start car and put a/c on, a/c blows hot. At this point, cooling fan is NOT on. After temp gauge in cab gets to about half way, cooling fan kicks on. At this point, a/c is still blowing hot. Any suggestions on what to check next??
Old 22 Aug 2011, 11:26 am
Default Re: 2007 pt cruiser a/c blowing hot
Is the clutch on the compressor engaging? If not you could simply be low on refrigerant. Other possibilities are a bad low or high pressure switch.
PT Patriot
2002 Patriot Blue PT Cruiser Touring Edition
Old 22 Aug 2011, 11:42 am
a/c compressor is NOT kicking on.
Old 22 Aug 2011, 11:44 am
It did not take freon.
Old 22 Aug 2011, 11:55 am
Recently the check engine light came on, went to parts store and determined it was a cam position sensor issue. I changed sensor, engine light went off and car is running fine, just with hot A/C. Can this be a computer issue?
Old 22 Aug 2011, 12:45 pm
What do you mean by "it did not take freon"?
You can try bypassing one or both of the pressure switches. Remove the connector for the switch and use a wire or something else electrically conductive to connect the two contacts together. Doing this will only tell you which switch is preventing the compressor from turning on. You will need to know what the suction and discharge pressures are to determine if the switch is faulty.
PT Patriot
Old 22 Aug 2011, 10:34 pm
My friend put gauges on and told me compressor wasn't kicking on and he couldn't put freon in. I was in a rush, thought it would be a quick freon charge and I would be on my way so I just closed the hood and left. Trying to troubleshoot and see if I can get a/c working.
Old 23 Aug 2011, 12:08 pm
You need to figure out why the compressor clutch is not engaging. Here are all the possible causes of the compressor clutch not engaging that I can think of in the order of most likely to least likely.
1. Low pressure switch open due to low refrigerant.
2. Low pressure switch open due to a bad switch.
3. High pressure switch open due to bad switch.
4. High pressure switch open due to high refrigerant pressure.
5. Bad wiring (A/C on/off switch, pressure switches).
6. Bad wiring (A/C clutch, A/C clutch relay).
7. A/C clutch relay bad.
8. A/C clutch bad.
9. PCM A/C clutch relay output bad.
Problems 1-5 above will keep the PCM from engaging the clutch and fan. Problems 6-9 should have the PCM trying to engage the clutch and the fan. Since you said that the fan does come on when the temperature is about half way but not when the A/C is on I would concentrate on problems 1-5.
PT Patriot
Old 23 Aug 2011, 04:45 pm
Does your AC fan turn on? I'm having similar situation. PT is the shop right now. It requires a new AC motor as my fan wouldn't turn on causing pressure build up in the system.
Old 25 Aug 2011, 12:46 pm
Trying to find low a/c pressure switch for 2007 pt cruiser; Local parts dealers don't have them (only high pressure). Anyone know where to buy one??
2007 PT Cruiser smileyval Tech & Performance Forum 1 05 Oct 2010 11:58 pm
Pt Cruiser 2007 Does not start Selim Tech & Performance Forum 2 06 Feb 2010 09:24 pm
2007 Pt Cruiser ptman4u Classifieds: For Sale/Trade 6 15 Oct 2009 03:19 pm
Just got my 2007 PT Cruiser!! LisaTrump General PT Cruiser Discussions 12 02 May 2009 05:49 pm
2007 pt cruiser jinky General PT Cruiser Discussions 10 15 Jun 2008 07:32 pm
