Sputers and chugs at lower RPMS
Old 23 Aug 2011, 04:50 pm
Unhappy Sputers and chugs at lower RPMS
Hello,
I have a 2001 manual trans.....when driving it will sputter at lower RPM's or at take off....seems to be getting worse! No codes I did have the cam shaft position sensor go out last winter....was having the problem before that but not as bad...Is my timing off, I pulled the cover off and it looks like its on but hard to tell, I have found no leeks in the air lines. Is my next step to change plugs and wires or should I have the timing checked?
Old 23 Aug 2011, 05:06 pm
Default Re: Sputers and chugs at lower RPMS
Originally Posted by marshall_strom View Post
Hello,
If your CMP sensor is under warranty i would return it/replace it first. I'm having the same issues right now.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=29148&dateline=131412  3683
2001 Touring Edition
Old 24 Aug 2011, 08:47 pm
Smile Re: Sputers and chugs at lower RPMS
The day I posted this i put new pluggs and wires on....problem SOLVED! so I am clear there was no codes, if anyone reads this and have not changed pluggs and wires do it, it was easy 7 bolts 4 wires 4 pluggs and put back together took around 1.5 hours at most. PLUGS should be gapped to .040 NOT .050
Engine chugs wiseone03 Tech & Performance Forum 0 17 Aug 2011 12:47 pm
HELP!!! Car cuts out at 2500 RPMS!!!! buo123 General Turbo Discussions 10 18 Mar 2011 01:26 pm
Engine surging at 4000 RPMs along with shaking at 2000 RPMs... brian5060 Tech & Performance Forum 3 24 Jul 2010 07:42 pm
Stutters during acceleration at low RPMs 2004PTGT General PT Cruiser Discussions 14 13 Jun 2009 10:17 am
Stumble at 4k rpms in neutral 05CruisergtHO General Turbo Discussions 1 24 Apr 2008 03:26 pm
