3 CEL Codes..
Old 23 Aug 2011, 08:06 pm
Default 3 CEL Codes..
Hey guys,
I'm new here, in fact this is my first post. My girlfriend has a 2005 PT Cruiser (Non-Turbo). It is a convertible, but I don't think that matters.
Anyways, ever since she bought the car, there has been a check engine light that comes on intermittently. I haven't figured out any sort of pattern to it coming on or going away. Sometimes it is there, others it is not.
I got around to reading the codes today with my friends ODBII scanner (I didn't know about the 3 key trick..)
P0171
P0172
P0138
I understand what they mean individually, but I think it is a bit off that they are coming on together. My best guess is that the O2 Sensor is bad (Back one)
Any feedback? I have no experience working on these cars, so I am not really sure of the common issues/problems/whatnot.
I did try to search the forums before posting, by the way.
Thanks
Old 23 Aug 2011, 08:15 pm
Default Re: 3 CEL Codes..
Odd that you get both 171 and 172 at the same time, considering 171 is "system too lean" and 172 is "system too rich". However, combine that with 138 and I agree, O2 sensor malfunction. Reads as bank 1, not sure if that's the upstream or downstream sensor.
Old 23 Aug 2011, 08:42 pm
I think it is post cat. Not 100% sure though..
Old 23 Aug 2011, 08:56 pm
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
I was once told that the 02 sensor codes are generic and to disregard the message about the "Bank" because the PT Cruiser doesn't have a choice between "banks' and only read the Sensor 1 or 2 and there was a debate about which one was which. Doesn't take long or a lot of $$ to change both and if one has gone bad, you can bet the other isn't far behind.
According to a Google search, sensor 2 is Post CAT
Old 23 Aug 2011, 09:17 pm
I just read on a performance forum that if one fails the other is likely to fail shortly after, and they also suggest replacing both.
Tags
cel, p0138, p0171, p0172, sensor
Codes? Help! garciawe Tech & Performance Forum 6 12 Apr 2011 02:00 am
TOO MANY CODES!!! Nonie Tech & Performance Forum 13 20 Mar 2011 12:21 am
Codes, Codes, everywhere there's Codes Neen Tech & Performance Forum 6 21 Nov 2008 07:59 pm
No Codes?? BB General PT Cruiser Discussions 2 13 Aug 2005 08:25 pm
obd codes camarillogolfer General Turbo Discussions 5 06 Aug 2004 11:10 am
