range sensor pt cruiser 2002
Old 24 Aug 2011, 08:47 am
Send a message via MSN to javolier
Smile range sensor pt cruiser 2002
Hi, anyone know
which range sensor (automatic transmission), and where it is located?
Old 24 Aug 2011, 09:24 am
Default Re: range sensor pt cruiser 2002
I hope that someone would serve
NOTE: The transmission range sensor is located within the transaxle. To remove the TRS the transaxle oil pan and valve body must be removed.
REMOVAL
Disconnect battery negative cable.
Remove engine air cleaner and tube.
Remove gearshift cable.
Remove manual valve lever.
Disconnect transmission range sensor connector.
Hoist vehicle.
Carefully remove transaxle oil pan and drain fluid.
Remove transaxle oil filter. Let transaxle oil drain fully.
Remove valve body retaining bolts.
Extract park rod from guide bracket and remove valve body from transaxle.
Place valve body on workbench.
Remove TRS retaining screw.
Remove manual shaft seal
Slide Transmission Range Sensor up the manual shaft and remove.
INSTALLATION
For installation, reverse removal procedure. Tighten TRS retaining screw to 5 Nm (45 inch lbs.) . Reseal transaxle oil pan using RTV.
Old 01 Oct 2015, 11:17 am
Does anyone have a diagram that shows where the overdrive and underdrive accumulators go? One has two springs and one has one spring- can't remember which accumulator goes into which hole. Thanks!
Old 01 Oct 2015, 03:06 pm
Not a PT but see this photo.
41TE Transmission Rebuild | Mechanical /Maintenance Forum | Bob Is The Oil Guy
(edit: looks like this might be Handy Cruiser on this website)
Also take a look a the spot on the valve body that the springs rest on. You'll likely see a witness mark showing which piston has the 2 springs.
______________________________________________
Most misunderstandings in the world could be avoided if people would simply take the time to ask, "What else could this mean?
2001 PT Cruiser LE 5 spd, original owner, no mods, MOOG arms with spherical bushing (ride is now a bit harsher vs OEM)
- 109K replaced timing belt/WP/tensioner/idler/crank&cam seals with same 1st gen design. That was a fun day and half!
- 119K Gates water pump failed after only 10K miles. Replaced with Airtex. This time around it was a 7 hour job.
2001 PT Cruiser LE AT 59K miles. Bought used, newest addition to the family
Oli Temp Sensor - 2002 2.2 CRD Help please!! zed2341 Tech & Performance Forum 8 04 Feb 2014 11:57 am
location of crankshaft sensor in 2002 dream crusier lilstarfire64 Tech & Performance Forum 1 23 Jul 2010 10:25 am
2002 CHRYSLER PT CRUISER **DREAM CRUISER** (hayward / castro valley) $9995 skylight craigslist 0 19 Jul 2007 09:02 pm
2002 CHRYSLER PT CRUISER **DREAM CRUISER** (hayward / castro valley) $9995 skylight craigslist 0 14 Jul 2007 04:30 pm
2002 CHRYSLER PT CRUISER **DREAM CRUISER** (hayward / castro valley) $9995 skylight craigslist 0 11 Jul 2007 08:11 pm
