A/C Fuses and Relays.
Old 24 Aug 2011, 10:54 pm
Default A/C Fuses and Relays.
So my teenage brother was replacing his battery in ihis 08 cruiserthen and installed it backwards. After he realized what he did the inside dome and stereo weren't working. We looked in the fuse box under the hood and found two blown fuses. We replaced those and everything works except the door locks and the ac. I was wondering if it could be a relay or fuse somewhere else other than the box that's causing this problem. The ac still blows air but nothing cold. Also the automatic door locks still lock all doors but will only unlock the drivers side front door. Any and help would be appreciated.
Old 25 Aug 2011, 11:36 am
Default Re: A/C Fuses and Relays.
Most relay circuits in the PT have one fuse for the coil and another fuse for the power it switches. My '02 is different than your brother's '08 so I couldn't tell you exactly which fuses to check but it is probably a good idea to check all of them. The relay itself shouldn't have been affected by the reversed battery conenction. One way to check the relay would be tro swap it with another one that is easy to check, for example the horn relay. If the horn does not work with the A/C relay, then replace the relay. If the horn works with both relays and the A/C works with neither, the problem is elsewhere.
PT Patriot
2002 Patriot Blue PT Cruiser Touring Edition
Old 25 Aug 2011, 08:29 pm
Do you know where the relays would be located? I've seen two or three on the firewall but not sure which is which.
Old 27 Mar 2015, 01:11 pm
So I have made the same bone head mistake rushing to change my wife's battery after work. Same issue as the original poster. When I hit the a/c the compressor clutch doesn't engage. Just curious if there's is a relay I can replace.
Edit: It's a 2007
Old 27 Mar 2015, 06:36 pm
767skyking's Avatar
Edit: It's a 2007
Internal relay in the TIPM... You need a DRB 3 or equivalent to reset
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 28 Mar 2015, 07:21 am
So I could go to a dealer to get it reset?
Old 28 Mar 2015, 08:48 am
767skyking's Avatar
I would recommend you to call the service department and ask what they charge to clear a DTC, then call around to other shops and ask if they have a DRB to clear and reset Chrysler TIPM's.
Old 28 Mar 2015, 11:05 am
I would suggest keeping in mind that the PCM output to the TIPM needs to be checked before replacing or repairing the TIPM. The PCM sends signals to the TIPM inputs on A/C clutch control.
On the TIPM there is a possibility that the circuit board or the components on the circuit board may need to be repaired. The TIPM is not designed to have the battery hooked up backwards and might have some internal components burnt or open contacts.
This is an example of what a TIPM looks like on the inside but this TIPM is not for a PT Cruiser. The purpose of the link below is just to show you how small the components are inside of a TiPM and when they are small they don't handle excessive electrical current.
Is your engine light on? Are there any engine trouble codes?
Old 28 Mar 2015, 12:15 pm
Is your PT Cruiser equipped with the Electronic Vehicle Information Center (EVIC)?
You might be able to reprogram it to get all the door locks to work again.
I would suggest trying to fix the problem by looking at page 8 on the pdf below that explains how to program to make all the doors unlock with the keyFOB with or without the EVIC.
http://www.chrysler.com/carryover/do...onvertible.pdf
Old 28 Mar 2015, 01:38 pm
I checked all of the fuses and everything works besides the compressor clutch.
I did have to replace the radio and door lock fuses.
Tags
a/c, door locks, relays
fan tests ok not coming on low or high, have new relays! azdave General PT Cruiser Discussions 38 24 Apr 2015 01:17 pm
Fan Relays - How Do You Disconnect Them? AlphaBob Tech & Performance Forum 5 09 May 2011 01:43 pm
need help with fuses!! rocketsigntist Tech & Performance Forum 9 05 Dec 2010 10:58 pm
on a 2007 pt cruiser is there more than one location for fuses and relays? 07ptcruzin Tech & Performance Forum 2 16 Jun 2009 06:49 am
fuses alice Stage Turbo Kits 7 07 May 2005 10:08 am
