Fan not running after shut off....
Old 25 Aug 2011, 08:00 pm
Default Fan not running after shut off....
Recently was having overheating issues. Changed the thermostat and temp sensor. Then the high and low relays. Next, I just recently replaced the cooling fan and fan motor assembly. The fan works while running, it turns on when it should...but when I turn the car off, the fan does not continue running. Any thoughts or suggestions?
Old 25 Aug 2011, 08:42 pm
Dill's Avatar
Default Re: Fan not running after shut off....
Is the fan supposed to be running while the car is off? Wouldnt that drain the battery?
Old 26 Aug 2011, 12:43 am
mdfrodolives's Avatar
My 2003's fan always turns off when I turn off the motor.
Tim
Old 26 Aug 2011, 01:49 am
Yep, that's how the PT is wired. Not all cars are so, but it is.
Old 26 Aug 2011, 09:43 am
Engine fan shut off on my '02 and does on my '05 when I turn key off, but on later PTs, I'm not sure...
Old 26 Aug 2011, 10:02 am
GhostFlyer's Avatar
Shuts off on the 06
2006 Touring, Inferno Red, Light gray interior, Pretty much stock for now.
Purchase date 7/29/11 69K miles
Old 26 Aug 2011, 03:30 pm
SCBluePT's Avatar
Shut off on my 2010 too.
Old 27 Aug 2011, 02:02 pm
ok thanks. all is well then. i remember my old honda did it. thought that most cars do it for a couple minutes then shuts off. thanks everyone.
PT Cruiser Won't Shut Off Tony440 Tech & Performance Forum 12 17 Oct 2019 07:33 am
shut down under power dckoone Tech & Performance Forum 2 26 May 2010 02:55 pm
Pt shut off while driving! ego957 Tech & Performance Forum 11 17 Jun 2009 01:42 pm
PT inside light keeps going on and off when car is shut off sani Tech & Performance Forum 4 11 Sep 2008 05:35 am
Engine Shut Off, Will Not Restart Stevearino Tech & Performance Forum 37 18 Oct 2007 11:55 am
