PT won't start
Old 25 Aug 2011, 09:48 pm
veracruise's Avatar
Default PT won't start
I have a 04 2.4L I can't get it to start, when I turn the key all the way
over to start it, will not even turn over, all lights work but could not hear
the fuel pump kick on. I hooked up a remote starter and the motor
did turn over but would not run. Anyone have any clues?
Old 25 Aug 2011, 10:34 pm
Dill's Avatar
Default Re: PT won't start
How many miles is on it? Over 80,000 id suspect the timing belt first even though that may not be it judging by youe description
Old 26 Aug 2011, 09:21 am
So you don't hear the fuel pump run for a second or two when the key is first switched to the "run" position. And the starter doesn't engage with the key but does with a remote starter switch. I would suspect a blown fuse. I don't have a wiring diagram handy right now to see if the functions share a fuse but it wouldn't hurt to check all of the fuses in the PDC. Then start checking relays. If the horn still works, swap the horn relay for the starter and fuel pump relay (one at a time of course) and see which functions work.
PT Patriot
2002 Patriot Blue PT Cruiser Touring Edition
Old 26 Aug 2011, 09:26 am
I would bypass the remote starter first. That should be the first thing you look at. You mentioned in your first post that it turns over with it but not with the key. Yank that thing out and put everything back to stock. Odds are, it's a problem with the remote start.
Old 26 Aug 2011, 09:55 am
VC said "I hooked up a remote starter". I understood that to mean a simple switch betwen the battery positive terminal and the starter solenoid.
PT Patriot
Old 26 Aug 2011, 11:12 am
veracruise's Avatar
Yes, thats the one I was talking about.
Old 26 Aug 2011, 11:13 am
veracruise's Avatar
It has 175,000 miles on it
Old 26 Aug 2011, 11:15 am
veracruise's Avatar
I put a new battery in new fuses and a new relay. Also put a new coil pack on
too
Old 26 Aug 2011, 03:49 pm
too
Did you do all this work before or after the starter would not engage with the key?
PT Patriot
Old 26 Aug 2011, 03:58 pm
rcktpwrd's Avatar
Something similar happened to mine back in December. Car drove great then went to get in to go somewhere and it wouldn't crank. Everything else worked like normal. Turn the key to the on position and the fuel pump didn't run and in the start position nothing happened either. I swapped around some of the relays with no change to anything. I was on vacation and had no other course of action but to have the car towed to the local Chrysler dealer and they found it to be a bad computer...
Joel
www.rcktpwrd.com
Will not start Oriphiel Tech & Performance Forum 28 03 Nov 2010 10:19 am
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
What a way to start the day!! Knotsobright1 General PT Cruiser Discussions 7 06 Oct 2009 12:00 am
Ran out of gas and now won't start Gracie512 Tech & Performance Forum 28 09 Jul 2009 10:15 pm
car won't start sonny562 Tech & Performance Forum 7 16 Aug 2004 08:14 am
