01 Speedometer light
Old 26 Aug 2011, 07:13 pm
Default 01 Speedometer light
One of the lights on my Instrument Panel is burned out. At night, I cannot see from 0-60mph. Everything else on the panel works fine. Are the bulbs easy to replace? I tried to search for Instrument Panel light replacements on the Forums, but can't seem to find one.
Old 26 Aug 2011, 09:09 pm
Default Re: 01 Speedometer light
there's a post in the how to section of technical. i just did my wife's last weekend and i think it took 1 1/2 hours. it's pretty detailed. might as well replace all 6 bulbs so you won't have to rip the dash apart again.
fyi, the bulb is a # 74.
Old 28 Aug 2011, 06:46 pm
WolfmanG's Avatar
our pt's are a lil different but if you follow the same steps in my how to, then you'll be able to get to your cluster to change your bulb. just make sure you don't lay your cluster flat. There's an oil in there that can seem thru and mess up your cluster
How To:2nd Gen Cluster & Pass Airbag Removal
-Danny Wolfman G
Old 28 Aug 2011, 07:04 pm
WolfmanG's Avatar
also here's a pic of where the bulbs are. Remember that these are twist lock lights. Meaning that there's two pieces, there's the twist lock base and the bulb. The bulb maybe kinda hard to take out of the base so be very careful.
-Danny Wolfman G
Old 04 Sep 2011, 03:07 pm
That pict is from my instructional: PT Dash Lamp Replacement It is pretty easy.
Nick
speedometer petiecruiser Tech & Performance Forum 1 12 Oct 2009 08:14 pm
speedometer 4SPEED Tech & Performance Forum 2 29 Sep 2006 05:00 pm
WTB: speedometer tony944 Classifieds: Want To Buy 0 01 May 2006 11:17 pm
Speedometer is off by 2 mph. Knucklehead Tech & Performance Forum 10 31 Aug 2004 02:46 am
