Error Code P1684
Old 27 Aug 2011, 11:44 am
Default Error Code P1684
My wife's PT shows an error code of "P1684" which translates to "Driver 5 Line 4". Any explanations as to what that means? Thanks
Old 27 Aug 2011, 12:42 pm
rcktpwrd's Avatar
Default Re: Error Code P1684
That is the code for the battery being disconnected in the last 50 starts, usually nothing to worry about.
Joel
www.rcktpwrd.com
Old 27 Aug 2011, 12:44 pm
From PT Do-It-Yourself.net:
P1684 does not indicate a problem; it's only a status, which indicates that the PCM memory has been cleared within the last 50 ignition cycles.
Old 04 Apr 2012, 04:58 pm
but what if the battery has not been disconnected in the past 50 starts...and this shows up anyways?
Old 04 Apr 2012, 05:29 pm
Your worrying to much. There could have been an instant loss of power or something to set the code. If you want to clear it, take off the negative battery cable for 5 minutes to reset the computer and clear all the stored codes.
Old 09 Jul 2012, 06:36 pm
I want to say thank you! I have a 2001 White PT Cruiser. My engine light came on today as soon as I entered the highway on the way to work. I was very worried all day about the expense that I was going to encounter. I checked the gas cap (it was loose) and I filled the tank but the light didn't go off. I went to Auto Zone, the employee ran a diagnostics test and was ready to sell me an EGR Valve/gasket. I was ready to buy that and a transducer and try to figure out how to install it. But thanks to you I learned how to get the error codes. Which were P1684 and P0455. Then I was able to learn that I don't have a real problem after all. Thank you for sharing your knowledge with me, a person that didn't marry a Mr. Fix it and doesn't have a mechanic in the family. You saved me a lot of stress and unnecessary repairs. I will be back to help my 18 year old learn how to do some maintenance repairs.
Thanks!
Old 09 Jul 2012, 06:57 pm
Doesn't work. Tried to teach my son the art of car maintenance even to change his own oil. Smart kid and started working at a job that paid over $100,000. He just pays someone to do everything. Bit him a couple days ago. He had problems with his Nissan. Called me and I said it's probably electrical and since he had no tools took it to the dealer. I just called. He paid $600 to have his alternator replaced. They told him it's a big job because he has a V6. Might be, can't tell, I'm in Fla he's in Virginia.
I guess that's not too bad. We have people here that pay that much for a new fan from the dealer.
Anyway, glad you learned something and saved some money and a headache. We're here 24/7 if you need us.
Old 13 Jul 2015, 10:55 am
I would like to thank you too Crewzin!! I have learned much about my PT through your posts!!
P1684 Error Code-How do I fix it? StreetCruiserUK Tech & Performance Forum 22 24 Sep 2011 07:50 am
code P1684 gyrene General PT Cruiser Discussions 10 27 Aug 2010 08:35 am
Error Code P1684 j_desan Tech & Performance Forum 1 17 Mar 2010 06:37 pm
Error Code P0442 and P1684????? Ramaboy Tech & Performance Forum 40 28 Jan 2010 06:36 am
error P1684 Driver 5 Line 4 Jargo Tech & Performance Forum 1 08 Dec 2009 04:05 pm
