replace power steering pressure hose
Old 27 Aug 2011, 07:01 pm
Default replace power steering pressure hose
Hi, guys,
My local dealer said the power steering pressure hose on my 04 PT Cruiser is leaking. They would charge $440 for replacing it. I thought it is ridiculous. I would do it by myself. Do you guys have any suggestion? Do I have to lift the car in order to change the hose?
Many thanks,
Joe
Old 27 Aug 2011, 07:10 pm
Default Re: replace power steering pressure hose
If it's leaking because it's contacting your differential cover, it should be covered under the D18 recall.
If it's leaking somewhere else, it wouldn't be covered but you could still use the recall part. It's bizarre but often Chryser will have a recall part and a regular part that are almost identical but the recall one is dirt cheap (so they don't have to pay so much for the claim, I believe). Anyways, price out this part number: CBTBD181
And it is a PIA to change but the dealer shouldn't be charging more than 2.0 hours of labor.
Old 27 Aug 2011, 07:25 pm
Hi, Floundering,
Thank you so much for the information. In fact I have never received any recall notice about the part. I was requesting an early state inspection on my car. The dealer stripped the sticker and asked for replacing the hose. Should I contact Chrysler first or just go ahead to ask the dealer fulfil this recall?
Joe
Old 27 Aug 2011, 08:41 pm
The recall is an inspection and adjustment and only replacement if it has been contacting the differential cover. If it's leaking somewhere else, it doesn't apply. The recall part should be cheaper though if it's not covered.
Old 28 Aug 2011, 04:38 am
swanjack's Avatar
I did this not so long ago, there was a hole in the rubber part of the hose. Getting the hose off the pas pump is a pita. If i was to do it again I think I'd take the radiator out first.
Old 14 Dec 2014, 08:35 pm
How did you get to the other end of the power steering hose?
Old 14 Dec 2014, 08:42 pm
The last post to this was 3 years ago.
Read this and see if it helps:
Power steering return hose replacement
power steering low pressure hose blowing off UpstateNYCruiser Turbo Wheels/Suspension/Handling 21 12 Oct 2015 01:59 am
Power steering high pressure hose leak. canbug Tech & Performance Forum 2 13 Mar 2011 08:16 pm
Replacing Power Steering Pressure Hose wapasha General PT Cruiser Discussions 0 20 May 2010 09:08 am
2006 cruiser power steering high pressure hose TOMisKING Tech & Performance Forum 0 01 May 2010 03:38 pm
Power Steering Hose Needed 340x Classifieds: For Sale/Trade 1 29 Jun 2009 04:53 pm
