AC problem? not sure..
Old 29 Aug 2011, 12:41 pm
demon666's Avatar
Default AC problem? not sure..
Hey guys just got back from over seas took out the PT for a drive and tryed to use my AC for the first time in the summer noticed that its not very cold i do feel some but not to wear it should be.. the temp out side is 84 .
my wifes car is a 2001 VW when i use her AC that gets super cold to wear i have to turn it off thats how i want my PT.. I never realy used it I live in Alaska , but the summers can be quit hot.
I have a 2004 pt cruiser 52.653 miles
Old 29 Aug 2011, 03:18 pm
Default Re: AC problem? not sure..
Welcome back. Possible it's only a little low in R134a and a recharge will fix you right up. However, the A/C system does need to be run even in the winter or between any long periods on non-activity because the freon also has lubrication with it and that lubricates the seals and "O" rings and keeps the system tight. If a charge gets it up and running again, you need to kind out how the old freon escaped.
Old 29 Aug 2011, 04:57 pm
demon666's Avatar
Thanks a lot for the info.
yet another A/C problem johnsealey General PT Cruiser Discussions 5 04 Dec 2011 08:33 pm
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
help, A/C problem :( drsarman Tech & Performance Forum 6 21 Sep 2010 04:04 am
a/c problem ergtic69 Tech & Performance Forum 3 28 Aug 2010 12:04 pm
a/c problem deez92 Tech & Performance Forum 11 25 Jul 2004 04:25 am
