white marks on top of engine, Antifreeze?
Old 29 Aug 2011, 04:10 pm
Default white marks on top of engine, Antifreeze?
Hi I have an 05 2.4 original rad, original hoses with 97xxx miles. I opened up my hood today and noticed white spots like a dried fluid on parts of the engine. My first thought was antifreeze leaking somewhere but where? The upper hose has been swelling alot in the st. louis heat. I did let it run for 30 minutes in the garage and nothing came out. I noticed the dried fluid on the top air manifold and all over the front of the cover the protects the throttle cable and link. there was also just a tiny bit on the battery, thats why I am thinking its the hose. Any help?
Old 29 Aug 2011, 04:12 pm
cruserdad1976's Avatar
Default Re: white marks on top of engine, Antifreeze?
could be a presuer leak that is getting blow by driving it did you chenk the radiator it could ahve a pin hole leak someplace in it
Old 29 Aug 2011, 04:36 pm
Cruiserdad has a point. If you can find a shop that has a pressure tester, they can put enough pressure in the coolant system to force even the smallest pinhole to show itself and reveal where the leak is.
Old 29 Aug 2011, 07:26 pm
ok i think i found two pinhole leaks on top of the plastic on the radiator, I know the right way to fix it is to get a new one but is there a cheep fix to seal it till I can get a new one?
antifreeze? fattmann Tech & Performance Forum 3 04 Jul 2010 12:29 am
White tape marks - solution! BGW Tech & Performance Forum 5 23 Jun 2009 12:56 pm
Strange Noise from engine and white smoke draven4099 Tech & Performance Forum 7 08 Jun 2009 01:05 pm
white marks on bumpers ravix Exterior Accessories Forum 8 13 Apr 2007 10:13 pm
Antifreeze PTGT Redman General Turbo Discussions 3 27 Sep 2003 01:21 am
