Error code question
Old 31 Aug 2011, 11:16 pm
Default Error code question
My engine light came on tonight, and when i did the key turn trick to get the code, what i got was P0456. In the sticky post there is no P0456, it goes from P0455 to P0460.
So-oooo, what does this code indicate?
'04 Touring Edition, bought new. Non-turbo, auto, 7 spoke wheels. Rear Spoiler. Charcoal interior, Inferno Red exterior.
Old 31 Aug 2011, 11:32 pm
WolfmanG's Avatar
Default Re: Error code question
P0456 - Evaporative Emissions System - Small leak detected
found it here OBD-II Trouble Code: P0456 Evaporative Emissions System - Small leak detected
-Danny Wolfman G
Old 31 Aug 2011, 11:33 pm
WolfmanG's Avatar
you know i had a code like that once but it went away after i changed my Camshaft position sensor. Have you had a problem with that sensor in the past?
-Danny Wolfman G
Old 01 Sep 2011, 12:56 am
Nope. Actually, my PT has been nearly trouble free for 138,000 miles. I've only replaced one rear wheel bearing, the timing belt (at 95000 miles), the engine cooling fan at 134000 miles, and for some crazy reason, had to have both rear door latches replaced. I've also replaced the tie rod ends, one ball joint, and another suspension part that I can't think of right now. All normal wear and tear items (for the most part), and one preventative maintenance item (timing belt). And I'm on my 3rd set of tires, plus 2 tires.
I tightened my gas cap, and if that doesn't do it, I'll buy another gas cap, and see what that does. I have a locking one, don't think I have the original one anymore....
Old 19 Sep 2011, 10:18 pm
Should have updated this a while ago. Replaced the gas cap, cleared the code by removing the battery cable, and all is well.
Old 20 Sep 2011, 06:19 am
Sorry I didn't see this sooner. Yes, that code is usually for the gas cap. Probably just not tightened (3 clicks) when you last filled up. It takes awhile (1 or 2 days), but once the cap is tightened, it will go away by itself.
is it an error Code or something else saraPT04 Tech & Performance Forum 5 08 Oct 2010 02:46 pm
Error Code bds02pt Tech & Performance Forum 2 29 Jan 2010 03:01 pm
error code... superpug666 Tech & Performance Forum 16 13 Oct 2009 07:33 pm
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
ruff outta the blu & error code question ptcruiserdad Tech & Performance Forum 5 27 Aug 2007 02:39 pm
