Fuser # 23
Old 02 Sep 2011, 05:05 pm
Smile Fuse #23
I have curiosity as of what does Fuse #23 "ENG ESD Relay Feed 3" means and what does it do. Any information provided will be greatly appreciated......
Old 02 Sep 2011, 05:18 pm
Default Re: Fuse #23
It's ENG ASD Relay fuse 3, not ESD! The other side of the ASD relay is fuse 18. The relay has three control feeds, if you look you should see two others, labled fuse 2 and fuse 1.
ASD Relay is the Auto ShutDown relay. The camshaft position sensor and crankshaft position sensor signals are sent to the PCM. If the PCM does not receive the signal within approximately 1 second of engine cranking, it deactivates the ASD relay and fuel pump control. When the relay/control is deactivated, power is shut off from the fuel injectors, ignition coils, oxygen sensor heating elements and fuel pump.
So, the ASD relay controls power to your fuel injectors, ignition coils, etc.
Old 02 Sep 2011, 05:24 pm
Default Re: Fuser # 23
uh, well, I was posting a response to one of Crewzin's posts, but all of a sudden it just disappeared....lmao.... maybe I need to renew my prescriptions.....
Old 03 Sep 2011, 01:03 pm
Thumbs up Re: Fuser # 23
Much appreciated, great explanation.
Old 03 Sep 2011, 02:07 pm
Chrome,
My response was for the ESD that was originally asked, but after reading your better answer that it was the ASD, I didn't think it was needed anymore.
Old 03 Sep 2011, 06:09 pm
Originally Posted by CREWZIN View Post
Chrome,
LOL, gave me a good laugh!
