Timing Question
Old 02 Sep 2011, 10:48 pm
Default Timing Question
I just installed the newer design timing set on my 2001 engine. The instructions stated that I should use a small allen wrench to hold the device in place while trying to adjust using the 6 mm wrench. I was unable to find a "hole" for the smaller allen to fit into so I simply held the moving "W" piece of metal with my flathead so that I could get the belt on. Timing is dead on after finishing up, but the "W" moves when I turn the engine over, is this normal? I assume that it is self adjusting the tension.
I am calling the moving part on the right side of the photo, rear of actual tensioner, the "W".
2001 PT Cruiser, Silver, Base, 2.4 ltr.
Old 03 Sep 2011, 11:25 am
rcktpwrd's Avatar
Default Re: Timing Question
Using a 1/4 ratchet on the plate your supposed to turn the plate until the 'w' part lines up with the tab on the engine.
Joel
www.rcktpwrd.com
Old 03 Sep 2011, 11:30 am
rcktpwrd's Avatar
Second post in this thread has a great picture of how it goes.
Timing belt DIY how-to tips needed...
Joel
www.rcktpwrd.com
Old 03 Sep 2011, 02:44 pm
Looking at those photos, looks like I have it right. Should the W move slightly when the engine is turned over?
Old 03 Sep 2011, 05:51 pm
rcktpwrd's Avatar
Yes, that is the spring tensioner moving as the belt tension changes....
Joel
www.rcktpwrd.com
Timing belt question maddyfan171 General PT Cruiser Discussions 9 19 Aug 2011 11:03 pm
Timing belt question slimjonesy Tech & Performance Forum 10 18 Jun 2011 04:30 pm
Another Timing Belt Question...(sorry!) sscanlan Tech & Performance Forum 10 17 Nov 2010 11:04 pm
Another possible timing belt question PTBlue_2002 Tech & Performance Forum 2 16 Jun 2009 06:51 am
Timing Belt Question bmore25 Tech & Performance Forum 2 28 May 2008 11:43 am
