Beep when car starts moving after changing front brake pads. No error code.
Old 05 Sep 2011, 06:12 pm
Default Beep when car starts moving after changing front brake pads. No error code.
I just changed the front brake pads on my 2001 PT Cruiser and everything seemed to go just fine, but now the car is making a beeping sound whenever the car starts moving after coming to a full stop. There is no visible warning lights and I cannot get an error code to display using the odometer and key trick.
I have driven around the neighborhood and the car seems to be operating correctly without any discernible noises or pulling to one side or another when braking. I had to remove some some of the brake fluid when I was compressing the calipers to get them back on, but the level is now solidly between the high and low marks on the side.
Does anyone know what my problem could be and/or how to correct it? I have already pulled the pads off one time and put it all back together and it displays the same problems.
Old 07 Sep 2011, 01:47 am
Default Re: Beep when car starts moving after changing front brake pads. No error code.
PROBLEM HAS BEEN RESOLVED:
The beep has gone away after a day, leading me to assume that the pads needed to wear down slightly before the piston would operate in the normal expected range of operation and/or there was some friction on the rotor that needed wear off. One of these was probably setting off a sensor and causing the beep. It has now gone away.
Front Brake Pads grmarch Tech & Performance Forum 2 19 Aug 2010 08:14 am
What front brake pads are people using? falconut General PT Cruiser Discussions 10 30 Jul 2010 12:41 am
2007 PT front brake pads? falconut Wheels, Tires, Suspension 2 02 Jul 2010 09:44 am
Brake pads Geordie Wheels, Tires, Suspension 4 02 Apr 2010 03:13 pm
Front ceramic front brake pads coopj40 General Turbo Discussions 1 17 Mar 2007 06:42 pm
