2007 PT Transmission Problems
Old 06 Sep 2011, 11:04 am
Default 2007 PT Transmission Problems
Hi, first time poster, I am a disabled AF retired vet, funds are limited and need to try and save money where and when possible. I know there is an option to go to a transmission shop, but they immediately wanted to replace the entire transmission off the bat for $1600, I can not afford that, and was wary of their immediate solution, went to another shop and they wanted $600 to replace the trans control solenoid. I am reaching out to try and find some sort of order to go to fix the problem.
I have a 2007 PT Cruiser. Automatic Trans. 2.4L Engine light on. codes 0700 0732, and 0734. Have replaced Transmission Control Solenoid, and transmission filter and fluid, it was pretty clean, alittle sludge around pan magnet, there are no strange sounds, runs fine up and switches smoothly up to the switch to four gear, then RPM revs up without shifting into fourth. Could it be the Transmission Speed Sensors (Input and Output); or the Transmission Range Sensor need to be replaced? or am I going to have to rebuild the entire transmission. Can anyone provide any thoughts on what it could be, or what order the sensors I can try before spending more than I have to, any thoughts or input (beyond take it to a transmission shop) would be appreciated. Thanks
2007 PT Cruiser Check engine light and transmission problems. jpierce2087 Tech & Performance Forum 18 22 Oct 2015 08:30 pm
2007 Pt with a transmission problem Sam31 Tech & Performance Forum 10 10 Nov 2010 09:28 am
2007 pt cruiser transmission clean daveone craigslist 3 04 Aug 2009 11:14 am
transmission filter 2007 bompa45 Tech & Performance Forum 5 26 Apr 2009 10:46 am
Possible Transmission Problems emhymas Tech & Performance Forum 1 03 Mar 2009 03:07 pm
