after market motor mounts??
Old 06 Sep 2011, 01:04 pm
mdskinner731's Avatar
Default after market motor mounts??
ok while looking at my car on the lift yesterday, i looked at my motor mount on the bottom again and the darn thing is blown apart again... its the second one i put in this car since january.. and i havent drove the car in almost 2 months?? i understand driving like i do is harsh on motor mounts but give me a break is there any where on line i could go to buy a better quality motor mount?? any mods i could do to help rectify this constant failing design??
Old 06 Sep 2011, 02:20 pm
cruserdad1976's Avatar
Default Re: after market motor mounts??
fill it with urathane thats what the Neon dudes say to do
Old 06 Sep 2011, 02:39 pm
rcktpwrd's Avatar
either fill it or get inserts for it.
I put Energy Suspension SRT-4 inserts in both torque struts on mine. There is a bit of vibration at idle but once moving it's not noticeable. The improvement in how the car accelerates off the line and during gear changes was amazing! I have a 5 speed with an auto trans there will be alot more vibration when stopped...
Joel
www.rcktpwrd.com
Old 06 Sep 2011, 03:19 pm
where would i find the press in-inserts for the motor mounts??
Old 06 Sep 2011, 03:49 pm
You can find them in Ebay.
PROTHANE NEON & SRT4 STREET URETHANE MOTOR MOUNT 00-06 | eBay
Energy Suspension Motor Mount Inserts Dodge SRT4 SRT-4 | eBay
Old 06 Sep 2011, 04:21 pm
rcktpwrd's Avatar
I got my stuff from here:
Energy Suspension Parts Dealer, Specializing in Energy Suspension Bushings Suspension Components.
Joel
www.rcktpwrd.com
Old 06 Sep 2011, 07:40 pm
You can also install the mounts from a neon srt-4. Their stock mounts are a lot tougher than the weak PT mounts.
Old 06 Sep 2011, 09:44 pm
mdfrodolives's Avatar
I replaced mine with Duralast struts from AutoZone. Ordinarily, I use OEM for just about everything, but since the OEM struts sucked, I figured I'd try aftermarket (after all, it wasn't an electrical part).
The first thing I noticed about the Duralast struts was that the rubber insert material was somewhat harder than the OEM's. That was a good thing. So I put them in (a perfect fit, BTW) and just happened to luck out: the top strut showed an adjustment of (4.70 inches). Perfect adjustment to specs. I didn't have to go through the adjustment procedure, at all (not that doing so is all that difficult).
By the way, if you're replacing struts all the time, it may not be totally because you're using struts with a cushioning material that is too soft. There is a reason why Chrysler instructs us to adjust the upper strut to the 4.70 inch distance. They're supposed to ride where they're supposed to ride in order to do what they do. You wouldn't skip adjustment on any other part of the car, would you? Why skip on this issue--especially if you're having to replace your struts again and again.
So far, so good. Although, my wife complained of a little vibration at idle, I felt none at all.
Lastly, the struts were cheap--compared to the dealer OEM, that was ....
Tim
Old 06 Sep 2011, 09:53 pm
ROCKETMAN8060's Avatar
If your getting motor mounts to put the inserts try your best to get OEM! Those aftermarket motor mounts are crap!
PT Cruiser used motor mounts! Original MOPAR - eBay (item 270813234098 end time Sep-13-11 08:37:49 PDT)
ROCKETMAN8060
Old 07 Sep 2011, 07:47 am
how wold i go about installing them in my pt?? they dont even look like mine??
Motor Mounts go-vair Turbo Performance 14 03 Apr 2017 10:50 pm
Motor mounts going bad wasmussen General PT Cruiser Discussions 31 07 May 2015 07:23 pm
Motor mounts sdwilson General PT Cruiser Discussions 4 13 May 2011 10:15 am
Motor mounts saldagus Tech & Performance Forum 6 15 Apr 2009 09:06 am
Motor mounts hoppyloop General PT Cruiser Discussions 13 02 Jul 2008 11:12 am
