manual or automatic pt cruiser
Old 07 Sep 2011, 12:48 pm
Send a message via MSN to javolier
Talking manual or automatic pt cruiser
I am interested in a sale of pt cruiser
I want to buy another PT, which will be better, manual or automatic?
both are turbo. but there are also classic no turbo
I could give comments.
Old 07 Sep 2011, 12:50 pm
Default Re: manual or automatic pt cruiser
Estoy interesado en la venta de PT Cruiser
Quiero comprar otro PT, que será mejor, manual o automático?
ambos son turbo. pero también hay clásicos
Podría dar comentarios
Old 07 Sep 2011, 12:55 pm
5 speed is better, if you don't want to have the problems you have been having.
El de 5 velocidades es mejor, para que no tengas los problemas que estas teniendo ahora.
If you are buying a GT go with the 5 speed for sure, because those trannies can handle more than 450 hp.
Si vas a comprar un GT, es 100% mejor el de 5 velocidades porque las transmisiones aguantan mas de 450 caballos de fuerza.
Old 07 Sep 2011, 12:58 pm
Kawizx9r's Avatar
What is your current PT now? Non-turbo (N/A) or turbo?
Reason I ask is because maintenance is a bit different between the two.
Turbo models should use only synthetic oil on oil changes, and depending if you're looking at a GT or Non-GT turbo model will determine what octane you run.
GT = 91/93 octane
Also, if you go with a turbo-equipped PT I'd suggest you look at getting a 5-speed. The automatics in the turbo models are the same as the N/A models and are very weak. Not saying that it won't last you awhile, I had 125k+ miles on my GT Automatic and the transmission shifted fine every time but you gotta baby them....especially if you mod them at all.
Kawi is a friggin genius!
Old 07 Sep 2011, 01:10 pm
rcktpwrd's Avatar
I prefer the 5 speed with either engine. To me it is much more fun to drive and they are also alot stronger than the automatic.
Joel
www.rcktpwrd.com
Old 07 Sep 2011, 01:25 pm
hola, tambien me ofrecen un toyota celica 4 cilindros, muy entero, año 2000, deme su opinion si sabe algo de estos autos.
Old 07 Sep 2011, 02:01 pm
Un Toyota Celica es un auto que casi no te va a dar problemas y te va a gastar mucho menos, pero un PT GT de 5 velicidades es un automovil unico.
The Toyota Celica is a car that is not going to give you a lots of problems and will give you better mileage, but a PT GT 5 speed is a very unique car.
Old 07 Sep 2011, 02:07 pm
entiendo, thanks
Old 07 Sep 2011, 05:23 pm
Mikadoo's Avatar
All depends on if you like shifting or not. Do you live in the city? Drive a lot in heavy traffic? Going to keep the PT several years?
I personally have been shifting cars and trucks for 40 years so I deserve an automatic for a change.
Far as turbo or not,,,do you want to drive a pig when you mash the throttle or a wildcat?
Old 07 Sep 2011, 06:47 pm
UptownSport's Avatar
autos are: Heavier, more expensive, less reliable, slower, more $$$ to repair,
less efficient and can be called 'slushbox'.
There's NO advantage to a slushbox unless you're disabled.
I personally believe the trans should be taxed; it's sent millions if not
billions of gallons into the exhaust pipe, heat exchanger or radiator needlessly.
In 5 years NO cars will have autos, they'll all have 'dual-clutches'; an
auto-shifted manual.
pt cruiser automatic transmission topic Cyclone35 General PT Cruiser Discussions 44 07 Feb 2017 06:06 pm
WTA: Solenoid Automatic Transmision My Pt.Cruiser Flx_18 Tech & Performance Forum 3 11 Mar 2011 03:29 pm
Reliability-Manual vs. automatic transmission pstar General PT Cruiser Discussions 8 29 Mar 2010 10:36 pm
Automatic/Manual throttle body.the same?? 6banger Tech & Performance Forum 3 05 Dec 2009 10:06 pm
automatic to manual popes Tech & Performance Forum 1 10 Jun 2008 09:32 am
