check engine light
Old 10 Sep 2011, 07:26 pm
Default check engine light
2006 pt cruiser 30,000 miles my check engine light stays on,i checked for codes by turning ignition switch on and off 3 times,no code displayed, but check engine light blinks on and off 10 times
Old 10 Sep 2011, 08:00 pm
Default Re: check engine light
According to owners manual for a 2001, the MIL (Malfunction Indicator Light) flashes to alert to serious conditions that could lead to immediate loss of power or severe catalytic damage. The vehicle should be serviced as son as possible if this occurs.
Are you sure your doing the code trick right? Follow the instructions precisely.
How to retrieve fault codes.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
check engine light ccprez Testing 12 16 Mar 2008 08:22 am
